Auto asub hetkel Raplamaal.
Veakoodide logi on spoileris.
Tuesday,22,February,2022,19:08:03:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.0.1 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WVWZZZ3CZCP016249 License Plate: PASSAT
Mileage: 179280km-111399mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 4C 4F 52 53 55
56 61 62 6C 72 77
VIN: WVWZZZ3CZCP016249 Mileage: 179280km-111399miles
on 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 000001-Engine -- Status: Malfunction 1110
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfuncti
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 058 Q HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6505
Revision: 00043014 Serial number: CU501108096737
Coding: 0000020
Shop #: WSC 37958 002 1048576
VCID: 3F8DF6FB6E7DB57E3B-806A
2 Faults Found:
006224 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 66
Reset counter: 40
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.14
Time: 20:36:21
006226 - Powertrain Data Bus
P1852 - 004 - Implausible Message ECU - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 49
Reset counter: 10
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.14
Time: 20:36:22
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AC HW: 3AA 614 109 AC
Component: J104 C2 450M VDF6 0022
Revision: --H07--- Serial number: 00000004576602
Coding: 0001402
Shop #: WSC 00028 028 00001
VCID: 6ED37BBF79970CF6E0-803A
3 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:53:30
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 6.75 V
Bin. Bits: 00011111
Count: 191
Hex Value: 0x0000
00532 - Supply Voltage B+
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:54:21
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 6.25 V
Bin. Bits: 00011111
Count: 115
Hex Value: 0x0000
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:54:21
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 5K0 907 044 ES HW: 5K0 907 044 ES
Component: Climatronic H18 1112
Revision: 00001003
Coding: 0004004802
Shop #: WSC 00028 028 00020
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 000F35079B030A8602-8054
2 Faults Found:
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 13
Reset counter: 246
Mileage: 179281 km
Date: 2022.02.21
Time: 20:36:21
13635840 - Supply voltage
U1011 00 [009] - Voltage too Low
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 18:54:10
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 E HW: 3AA 937 087 E
Component: BCM PQ47 H+ 413 0455
Revision: BC413001
Coding: 0008000000000000001C0280540029F423D50088646C8D60E48046240041
VCID: 3C7781F7BF6BAE661E-8068
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 05071 10 0603
Coding: 00B795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 050811 05 54 0403
Coding: 02302A
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:51:58
Freeze Frame:
Term 15 On
Voltage: 8.70 V
ON
OFF
ON
OFF
OFF
00526 - Brake Light Switch (F)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:51:45
Freeze Frame:
Term 15 On
Voltage: 9.15 V
ON
ON
ON
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:53:40
Freeze Frame:
Term 15 On
Voltage: 6.45 V
ON
OFF
ON
OFF
OFF
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:51:46
Freeze Frame:
Term 15 On
Voltage: 9.15 V
ON
ON
ON
OFF
OFF
Address 10: Park/Steer Assist (J791) Labels:| 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261120001294
Coding: 348105
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000.rod
VCID: 4487F917CF9BD6A666-8010
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 18:52:37
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 13:30:05
12648481 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 179281 km
Date: 2022.02.21
Time: 20:36:20
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__101 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PE54VV4
Coding: 0012337
VCID: 4C97D1372FCB1EE6AE-8018
Subsystem 1 - Serial number: 6332MTS619852061
Subsystem 2 - Serial number: 6342MTS624962061
Subsystem 3 - Serial number: 6351HTS68BH9AAKR
Subsystem 4 - Serial number: 6361HTS6OKM9V9KR
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:54:26
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110806100149
Coding: 098A250001
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 6BD572AB8285F9DEC7-803E
Multifunction steering wheel control module:
2 Faults Found:
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 18:52:39
136194 - Supply voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 18:52:39
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3AA 920 870 C HW: 3AA 920 870 C
Component: KOMBI H03 0607
Coding: 160F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
VCID: 326BAFCF652F6816C4-8066
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 18:52:42
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H41 1620
Revision: H41 Serial number: 030811F2000256
Coding: 461006
VCID: 397998E3B0599B4E05-806C
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 246
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.14
Time: 20:36:21
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:53:40
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3AA 959 799 A HW: 3AA 959 799
Component: IMMO 083 0400
Revision: 00083000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 4683E31F31A7E4B678-8012
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
2 Faults Found:
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 5
Fault Frequency: 4
Reset counter: 31
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:55:40
02817 - Steering Column Lock; Enabling Wire from Steering Wheel Electronics
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 31
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.15
Time: 12:46:28
Address 37: Navigation Labels: None
VCID: 55A13453BC015F2E01-FFFE
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.309 1002
Revision: 1AH03733 Serial number: 00112200109801
Coding: 0000258
VCID: 3C7781F77F6BAE661E-8068
6 Faults Found:
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 31
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.14
Time: 20:36:19
Freeze Frame:
Term 15 On
RPM: 0 /min
Speed: 0.0 km/h
(no units): 8.0
Voltage: 11.30 V
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 37
Reset counter: 31
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.14
Time: 20:36:21
Freeze Frame:
Term 15 On
RPM: 1500 /min
Speed: 0.0 km/h
(no units): 8.0
Voltage: 11.30 V
000 - - - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 31
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 13:30:01
Freeze Frame:
Voltage: 4.70 V
Voltage: 9.30 V
Voltage: 9.30 V
Not Occup.
Not Occup.
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 4
Fault Frequency: 4
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 13:30:39
Freeze Frame:
Voltage: 0.30 V
Voltage: 10.60 V
Voltage: 2.60 V
Not Occup.
Not Occup.
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 31
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:52:12
Freeze Frame:
Voltage: 4.00 V
Voltage: 8.00 V
Voltage: 8.00 V
Not Occup.
Not Occup.
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 31
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:52:12
Freeze Frame:
Voltage: 4.20 V
Voltage: 8.00 V
Voltage: 8.00 V
Not Occup.
Not Occup.
Address 46: Central Conv. Labels:. 3C0-959-799-46.clb
Component: 01 KESSY PQ47 083 0337
Coding: 01910A0002C60E763004941572004FCE70780103242498
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Subsystem 2 - Component: NGS No Answer
Subsystem 3 - Component: IRUE No Answer
Subsystem 4 - Component: ViP n.mounted
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:53:39
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1620
Coding: 00000008
VCID: 6FED66BBBE9D05FEEB-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0003
No fault code found.
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0003324264
Coding: 0000B6
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
VCID: 366393DF89477436E8-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0408
Serial number: 00000002366023
Coding: 000090
3 Faults Found:
68108 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 179281 km
Date: 2022.02.21
Time: 20:36:21
65793 - Supply voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 18:52:38
131329 - Rear Door Control Module
B11ED F0 [009] - Supply Voltage too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 18:52:39
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000147489
Coding: 0022157
VCID: 356194D35C417F2EE1-8060
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.14
Time: 20:36:19
Freeze Frame:
Voltage: 11.60 V
Count: 65
Speed: 0.0 km/h
Hex Value: 0x1261
Hex Value: 0x0001
Hex Value: 0x0808
Freeze Frame:
Fault Priority: 2
Fault Frequency: 55
Reset counter: 246
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.14
Time: 20:36:21
Freeze Frame:
Voltage: 11.30 V
Count: 71
Speed: 0.0 km/h
Hex Value: 0x1273
Hex Value: 0x0001
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:53:39
Freeze Frame:
Voltage: 6.60 V
Count: 48
Speed: 0.0 km/h
Hex Value: 0x1270
Hex Value: 0x0001
Hex Value: 0x0101
Freeze Frame:
Fault Status: 01110010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:56:40
Freeze Frame:
Voltage: 6.10 V
Count: 50
Speed: 0.0 km/h
Hex Value: 0x1271
Hex Value: 0x0021
Hex Value: 0x0101
Address 55: Headlight Range
Cannot be reached
Address 56: Radio Labels: None
No Faults Found
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1620
Coding: 03220858
VCID: 71E960C3A8A9130EFD-8024
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 00000000008900953341
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3AE 907 441 HW: 3AE 907 441
Component: J772__Rearview 0020
Revision: 00H13000 Serial number: 525 PA8J394108
Coding: 0020006
Shop #: WSC 39831 002 1048576
VCID: 72EB6FCF6DAF281604-8026
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 13:30:08
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:52:38
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 77: Telephone Labels: RETROFIT77.lbl
Part No SW: KTC 364 96P HW: KTC 364 96P
Component: SWP:3.31.6 H24 0199
Revision: 00000000 Serial number: 00000000000000
Shop #: WSC 21977 142 74100
VCID: 3E738BFF6977BC7630-806A
End-------------------------(Elapsed Time: 03:50)--------------------------
www.Ross-Tech.com
56 61 62 6C 72 77
on 0010
Address 01: Engine
Cannot be reached
Coding: 0000020
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 66
Reset counter: 40
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.14
Time: 20:36:21
Freeze Frame:
Fault Priority: 0
Fault Frequency: 49
Reset counter: 10
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.14
Time: 20:36:22
Coding: 0001402
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:53:30
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 6.75 V
Bin. Bits: 00011111
Count: 191
Hex Value: 0x0000
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:54:21
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 6.25 V
Bin. Bits: 00011111
Count: 115
Hex Value: 0x0000
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:54:21
Revision: 00001003
Coding: 0004004802
2 Faults Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 246
Mileage: 179281 km
Date: 2022.02.21
Time: 20:36:21
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 18:54:10
Revision: BC413001
Coding: 00B795
Coding: 02302A
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:51:58
Freeze Frame:
Term 15 On
Voltage: 8.70 V
ON
OFF
ON
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:51:45
Freeze Frame:
Term 15 On
Voltage: 9.15 V
ON
ON
ON
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:53:40
Freeze Frame:
Term 15 On
Voltage: 6.45 V
ON
OFF
ON
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:51:46
Freeze Frame:
Term 15 On
Voltage: 9.15 V
ON
ON
ON
OFF
OFF
Coding: 348105
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 18:52:37
U1400 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 13:30:05
12648481 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 179281 km
Date: 2022.02.21
Time: 20:36:20
Coding: 0012337
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:54:26
Coding: 098A250001
2 Faults Found:
U1400 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 18:52:39
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 18:52:39
Coding: 160F01
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 18:52:42
Coding: 461006
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 246
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.14
Time: 20:36:21
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:53:40
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 31
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:55:40
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 31
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.15
Time: 12:46:28
No Faults Found
Cannot be reached
Coding: 0000258
6 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 31
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.14
Time: 20:36:19
Freeze Frame:
Term 15 On
RPM: 0 /min
Speed: 0.0 km/h
(no units): 8.0
Voltage: 11.30 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 37
Reset counter: 31
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.14
Time: 20:36:21
Freeze Frame:
Term 15 On
RPM: 1500 /min
Speed: 0.0 km/h
(no units): 8.0
Voltage: 11.30 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 31
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 13:30:01
Freeze Frame:
Voltage: 4.70 V
Voltage: 9.30 V
Voltage: 9.30 V
Not Occup.
Not Occup.
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 13:30:39
Freeze Frame:
Voltage: 0.30 V
Voltage: 10.60 V
Voltage: 2.60 V
Not Occup.
Not Occup.
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 31
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:52:12
Freeze Frame:
Voltage: 4.00 V
Voltage: 8.00 V
Voltage: 8.00 V
Not Occup.
Not Occup.
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 31
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:52:12
Freeze Frame:
Voltage: 4.20 V
Voltage: 8.00 V
Voltage: 8.00 V
Not Occup.
Not Occup.
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:53:39
Coding: 00000008
Coding: 0000B6
Slave Passenger:
Coding: 000090
3 Faults Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 179281 km
Date: 2022.02.21
Time: 20:36:21
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 18:52:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Date: 2022.02.22
Time: 18:52:39
Coding: 0022157
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.14
Time: 20:36:19
Freeze Frame:
Voltage: 11.60 V
Count: 65
Speed: 0.0 km/h
Hex Value: 0x1261
Hex Value: 0x0001
Hex Value: 0x0808
Freeze Frame:
Fault Priority: 2
Fault Frequency: 55
Reset counter: 246
Mileage: 179281 km
Time Indication: 0
Date: 2016.07.14
Time: 20:36:21
Freeze Frame:
Voltage: 11.30 V
Count: 71
Speed: 0.0 km/h
Hex Value: 0x1273
Hex Value: 0x0001
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:53:39
Freeze Frame:
Voltage: 6.60 V
Count: 48
Speed: 0.0 km/h
Hex Value: 0x1270
Hex Value: 0x0001
Hex Value: 0x0101
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:56:40
Freeze Frame:
Voltage: 6.10 V
Count: 50
Speed: 0.0 km/h
Hex Value: 0x1271
Hex Value: 0x0021
Hex Value: 0x0101
Cannot be reached
No Faults Found
Coding: 03220858
Coding: 0020006
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 13:30:08
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 246
Mileage: 179282 km
Time Indication: 0
Date: 2016.07.15
Time: 18:52:38
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
