Hooldusv?lba muutmine (Golf, Jetta)
Erinevaid linke seoses Volkswageniga.
Strand
Auto: VW Passat B6 4motion 2.0TDI
Lugemata postitus Postitas Strand »
Tekst on inglise keeles, copy'n ta igaksjuhuks siia ka, et ?kki v?etakse sait maha ajajooksul. Muidu asetseb asi lehek?ljel: http://www.smailus.com/thomas/vw/vw.service.html
PROGRAMMING THE SETTINGS OF THE VARIOUS SERVICE COUNTERS.
It is possible to program the current settings you want for the counters.
This used if the speedometer console is replaced or if you want to set your
intervals to a shorter value than the factory. For example, you can set the
computer to display OEL after only 3000 miles.
1. Turn on the ignition (do not start the car)
2. Depress the trip-reset button on the odometer.
Also depress the button to set the MINUTES of the digital clock (lower one).
3. The LCD display should read "OEL 1,S", where the S indicates SET.
4. Using the trip-reset button, you can call up the following counter banks
for the service intervals in sequence:
OEL 1,S - distance counter for oil change (ie 7500 miles normally)
OEL 2,S - time counter for oil change (ie 12 months)
IN 01,S - time counter for yearly service interval (ie 12 months)
IN 02,S - distance counter for special service (ie 15,000 miles )
5. Using the button for setting the MINUTES on the digital clock (lower one),
you can display the value of the counter. Repeated pressing of the button will
select a subsequent lower value of the counter and at the lowest level, it will
reset to the highest level and begin to decrease again. The step sizes are
blocks of miles (500 miles, I think) and months (the time setting for the
yearly service is a bit strange as I think it can be set to 1,2,3,4,5 or 6.
Maybe it counts in 2 month blocks? Does anyone know?).
6. Once you have set each counter to the value you want, turn off the ignition.
7. Work is done.
Typed form a german service manual by Thomas Smailus (tom@rsip.lsu.edu) for
use by the VW community. This data is for informational use only and there are
no implied guarantees or warrantys as to its applicability or usability on
anyones specific vehicle. Use this information at your own risk.
Ei leidnud siit foorumist midagi sarnast, kui on olemas siis palun kustutage, v?i liigutage paremasse kohta. :)
Stollu
on keegi seda ka katsetanud juba ?
puna1
Auto: VW Passat CC
Lugemata postitus Postitas puna1 »
Mis teie eesm?rk on ja mis mootoritega seda teha kavatsete.
Minu masinal on hooldusv?lp 30000 tagant.
Kasutan teist filtrit ja head ?li BP Visco 7000 sport ~250.-kr/L mis seda kannatab.
Turbomootoritele ei soovita k?ll ?le 10000km seda vahetust venitada.
Tänanud: 85 korda
Tänatud: 178 korda
...if you want to set your intervals to a shorter value than the factory.
ehk siis saab ainult l?hema v?lba seada mis iseenesest ei tee ju halba. Kui sul on erinev s?idustiil (takso, palju k?lmk?ivitusi v?i t??tamist seisva autoga) siis hea kui teed ?livahetust sagedamini. Kommentaare?
Mine “Lingid”
