Pisike Vag-com probleem
marq1983
Auto: MKV R32.
Lugemata postitus Postitas marq1983 »
Kood: Vali kõik
Monday,18,June,2012,15:12:29:10074
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 22 25 37 42 44 46 47 52 55 56 62
          72 76 77
VIN: WVWZZZ1KZ7W007216   Mileage: 178690km/111032miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 CE    HW:
   Component: MOTRONIC ME7.1.1G   6733
   Revision: --H01---    Serial number: VWZ7Z0F4078479
   Coding: 0000178
   Shop #: WSC 01269 785 00200
   VCID: 50AB7473BA73
1 Fault Found:
000406 - Engine Oil Temp. Sensor (G8): Implausible Signal
               P0196 - 004 - No Signal/Communication - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 047 F    HW: 02E 927 770 AD
   Component: GSG DSG         082 1164
   Revision: 05108020    Serial number: 00001007201181
   Coding: 0000020
   Shop #: WSC 44551 111 44551
   VCID: 1B31D35FA335
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-614-517-MK60-A.lbl
   Part No SW: 1K0 614 517 AD    HW: 1K0 614 517 AD
   Component: ESP 4MOTION MK60-AT 0102
   Revision: 00H13001
   Coding: 0004744
   VCID: 69DDB99739E9
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 70EBD4F31A33
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000005770469
   Coding: EE8FCE0700041500641400001400000000097B075C
   Shop #: WSC 01392 785 00200
   VCID: 2B51039FF395
   Part No: 1K1 955 119 E
   Component: Wischer 120506 020  0501
   Coding: 00038805
   Shop #: WSC 01392
   Part No: 1K0 955 559 T
   Component: RegenLichtSens 011  1110
   Coding: 01007949
   Shop #: WSC 01392
2 Faults Found:
01834 - Bulb for Side-Blinkers; Left (M18)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 96
                    Mileage: 178695 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.05 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01835 - Bulb for Side-Blinkers; Right (M19)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 96
                    Mileage: 178695 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.05 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 Q    HW: 1K0 909 605 Q
   Component: 5J AIRBAG VW8R  033 7900
   Revision: 04033000    Serial number: 0038LD091FB
   Coding: 0013642
   Shop #: WSC 01279 785 00200
   VCID: 3A7F36DB0CCF
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0012122
   VCID: 77F9EFEF7F5D
   Part No: XXXXXXXXXXX
   Component: E0221           002 0010
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 873 B    HW: 1K6 920 873 B
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0F4078479
   Coding: 0004103
   Shop #: WSC 00011 888 96745
   VCID: 316D11F7D1B9
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 310010651504B9
   Coding: FF3F07CA07000002
   VCID: 2C530083F69B
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 F
   Component: Haldex 4Motion      0115
   Coding: 0000001
   VCID: 306B14F3DAB3
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1610
   VCID: 316D11F7D1B9
Address 37: Navigation        Labels: 1K0-919-887-MFD2.lbl
   Part No: 1K0 919 887 F
   Component:      Navigation     0028
   Coding: 0000101
   VCID: 3C7330C306FB
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         005 0971
   Coding: 0000182
   VCID: 397D29D709C9
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.141 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 346318E32EAB
2 Faults Found:
00003 - Control Module
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
             Freeze Frame:
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Mileage: 0 km
                    Temperature: -70.0°C
                    Voltage: 0.00 V
                    Voltage: 0.00 V
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0202
   Revision: 00020000    Serial number: 00000000000000
   Coding: 1A90020051030C3E2D0285057008CFC6F0F800
   VCID: 83010B3FBB85
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Part No: 1K0 951 178
   Component: Neigungssensor  001 0101
   Component: Innenraumueberw.001 0101
Address 47: Sound System        Labels: 3C0-035-456.lbl
   Part No: 1K6 035 456 A
   Component: 08K Audioverst.     0005
   Revision: 00003000    Serial number: 00000000001315
   VCID: 2A5F069BFC6F
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000438
   VCID: 3A7F36DB0CCF
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000004
   VCID: F4E358E3EE2B
Address 56: Radio        Labels: 1K0-035-095.lbl
   Part No: 1K0 035 095 G
   Component:        Radio        0028
   Coding: 0012040
   VCID: 295DF997F969
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         004 0910
   Coding: 0000144
   Shop #: WSC 01269 785 1012552
   VCID: 387B2CD332C3
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
   VCID: 397D29D709C9
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D550D87CD81
Address 77: Telephone        Labels: 3C0-035-729.lbl
   Part No SW: 3C0 035 729 E    HW: 3C0 035 729 E
   Component: Telefon             6009
   Revision: 00009000    Serial number: 0000000729412
   Coding: 0016043
   VCID: 2545F5A79571
End   ---------------------------------------------------------------------
Mure nimelt suunatulede veakoodides. Ütleb, et lamp läbi aga kõik lambid töötavad. Veakoodide kustutamisel tulevad nad kohe tagasi kui suunda näitan. jama algas peale seda kui vahetasin välja vasak poolse peegli suunatule.
Tänanud: 53 korda
Re: Pisike Vag-com probleem
Kas on lihtsalt veakoodid ajus või paneb auto ka mingi tulukese põlema?
Äkki mingid valed pirnid sees, näiteks LEDid või siis vale võimsusega.
marq1983
Auto: MKV R32.
Jah armatuuris läheb ka tuluke põlema ja parda arvutis ütleb, et vasak ja parem lamp läbi. Mäletamist mööda ostsin originaal suunatule, ah jah tagumise tule vahetasin ka välja vb seal mingi vale pirn sees, kuigi ostsin ka selle originaali. Uurin järgi
Tänatud: 155 korda
dellu kirjutas:Äkki mingid valed pirnid sees, näiteks LEDid või siis vale võimsusega.
G5 suunatuled on peeglites ja vahetatakse terve tuli. Mingi "vale võimsus" võibolla B-osa teema. Endal üks suund vahetatud B osaga ning sellist probleemi küll pole.
Kas suunad reaalselt ka toimivad või mitte? Äkki pistikud, mis suunatuledesse lähevad on ära mädanenud?
Ühtlasi, kas kollast roolitulukest ei põle armatuuris? Ma näen, et sul rooli asendianduri adaptatsioon tegemata. Pane masin käima, keera rool seinast seina ja siis keera rool sirgeks (võimalikult sirgeks) ning sõida edasi mitte kiiremini kui 5kmh.
Viimati muutis siLc, 20 Juun 2012, 10:05, muudetud 2 korda kokku.
marq1983
Auto: MKV R32.
siLc kirjutas:
Kõik suunad töötavad ja tagumised pirnid on ka ok. ja roolitule sain korda tänud. Niikuinii hooldusesse minik vb oskavad nad seal midagi teha selle suunatule veakoodiga.
marq1983
Auto: MKV R32.
Problem solved. Piinlik lugu :D Mul oli side blinkers enabled vag-comis aga reaalselt mul neid auto küljes ei ole tuleb välja. Igaljuhul kui ma need disablesin siis veakood kadus ja kõik suunad kaasaarvatud peegli omad töötavad ja õnnelik oma 0 veakoodi üle :D
Viimati muutis marq1983, 21 Juun 2012, 12:04, muudetud 1 kord kokku.
