golf 3 gti diiselmootor
Re: golf 3 gti diiselmootor
t6nis3 kirjutas:Jääb siiski et,GTI.on bensiini tarbiv mootor,kogu lugu. Samas ,kui vaidlete on ju ka TDi. bensiinikas---naeru koht .Iroonia loomulikukt. Antke teada,kellel on GTI. DIISEL MOOTORIGA AUTO .
Selline G3 ju siin foorumiski olemas?
tlauri
Tänatud: 17 korda
GTI TDI "das uskumatu Toomastele" :)
Stollu
GTO (Gran Turismo Omologato) a homologated car for racing (used by Ferrari, Pontiac and Mitsubishi).
GTS (Gran Turismo Spider) a convertible GT car. For example the Ferrari 348 GTS.
GTB (Gran Turismo Berlinetta) a coupe style GT. For example the Ferrari 328 GTB.
GTV (Gran Turismo Veloce) a fast GT car. For example the Alfa Romeo GTV6.
GTI or GTi (Gran Turismo Iniezione) a fuel injected GT, first used on the 1961 Maserati 3500 GTI.
GTE or GT/E (Einspritzung - German for fuel injection) used on the Opel Manta GT/E.
GTA (Gran Turismo Alleggerita) a lightened GT car. For example the Alfa Romeo GTA.
GTAm (Gran Turismo Alleggerita Modificata) a modified, lightened GT car such as the Alfa Romeo GTAm.
GTC (Gran Turismo Compressore/Compact/Cabriolet/Coupe/Crossover) for example Alfa Romeo 6C 1750 GTC (Compressore), Opel Astra (compact), Bentley Continental GTC (cabriolet), Ferrari 330 GTC (coupe), Opel Antara GTC (crossover)
GTD (Gran Turismo Diesel), used by Volkswagen in sport oriented Golf version.
GTR or GT-R, (Gran Turismo Racing), as in the McLaren F1 GTR, Mercedes-Benz CLK GTR, and Nissan GT-R
HGT (High Gran Turismo), used by Fiat in sport oriented cars version.
GTI TDI
Hõbedane "TDI" 90 hj
Punane "I" tähistab 110 hj
Punane "DI" tähistab 130 hj
Punane "TDI" tähistab 150 hj
"TDI" on registreeritud VW Grupi kaubamärk.
Viimati muutis Stollu, 26 Aug 2013, 14:16, muudetud 1 kord kokku.
Tänatud: 44 korda
Stollu. Sinu tabelist nähtub ka,et VW-genit. GTI-d.polnud. (Maserati). Samas loe tabelit,kus on kirjas GTD, VW-en. Rohkem VW-ile varjante ei pakuta ju ,kui DIISEL GTD.
corbe
Auto: A5
Lugemata postitus Postitas corbe »
Mk4 1.9 tdi 110kw mootorikoodiga ARL oli UK-s täitsa GTI TDI nimega inimestele saadaval.
http://www.ultimatespecs.com/car-specs/ ... I-150.html" onclick="window.open(this.href);return false;
Ja täitsa oli sellise mootoriga isend minu käes, lausa 4motion. Peaks ka tänasel päeval Eesti ja Soome vahet liikuma.
Viimati muutis corbe, 27 Aug 2013, 21:26, muudetud 1 kord kokku.
Stollu
Tõnis - ausalt öeldes mind ei huvita ka , kes tahab närib oma diisli tähti , kes tahab ei näri oma diisli tähti
Viimati muutis Stollu, 27 Aug 2013, 21:28, muudetud 1 kord kokku.
Stollu
corbe kirjutas:Mk4 1.9 tdi 110kw mootorikoodiga ARL oli UK-s täitsa GTI TDI nimega inimestele saadaval.
Tundub mingi poolik lehekülg , ei leia enda auto tehnilisi andmeid
Tänatud: 44 korda
USA- s. oli Vento JETTA nime all. UK.ei allu ka oma mootori tähistustega Euroopaga.
Tänatud: 44 korda
Tänatud: 202 korda
t6nis3 kirjutas:USA- s. oli Vento JETTA nime all. UK.ei allu ka oma mootori tähistustega Euroopaga.
Kas sa tõnis saad aru, et Euroopas müüdi 1000 20 aasta erimudeli GTI-d, millest 600 oli 8 klapilised 150 16 klapilised ja 250 neist oli TDI mootoriga. Me ei räägi praegu siin tavalisest GTI-st vaid 20 aasta erimudel GTI-st...
Tänatud: 44 korda
Lehekülg ei ole poolik. Konkreetne. Seal mainitud üks GTI. G4 1,8 T.
Tänatud: 44 korda
golfi-vend. Mitte ükski tabel ei näita ET GTI. ON DIISEL MOOTORIGA EUROOPAS.
Tänatud: 44 korda
Tänatud: 202 korda
Sest see pole GTI vaid 20th Anniversary GTI.
Golf GTI TDI: 1,9 l 81 kW (wurde so als Sondermodell 20 Jahre GTI von 1996 bis 1997 gebaut, der Motor war jedoch auch im CL, GL oder GT erhältlich), max. Drehmoment 235 Nm, Motorkennbuchstabe: AFN
Tahad tõlgid ise ära, muidu pea edasipidi oma suu kinni selle kohapealt. ;)
Tänatud: 44 korda
Täpselt sama auto. Kuid mitte GTI ,vaid GT.-TDi.
Tänatud: 202 korda
Ega siis midagi kui tõlgime ise ära... -_- . Golf GTI TDI: 1.9L 81 kw(Ehitati kui erimudel 20 aasta GTI 1996 kuni 1997, sama mootorit kasutati teistel mudelitel nagu CL, GL või GT) Maksimum väändemoment 235 Nm, Mootorikood : AFN.
Kui ei usu ikkagi, et selline mudel olemason võta http://mobile.de" onclick="window.open(this.href);return false; lahti ja otsi GTI TDI, vaevalt, et kõik need 16 mudelit, mis seal müügis on on nyyd kuskilt kokku ehitatud GTI istmete, käigukanginuppude ja GTI embleemidest, omades samas diiselmootorit.
tlauri
Tänatud: 17 korda
Kirjuta VAG presidendile, et sa pole minevikus aset leidnud sündmuste ja olukorraga absoluutselt rahul :D.
t6nis3 kirjutas:Täpselt sama auto. Kuid mitte GTI ,vaid GT.-TDi.
Tänatud: 202 korda
tlauri kirjutas:Kirjuta VAG presidendile, et sa pole minevikus aset leidnud sündmuste ja olukorraga absoluutselt rahul :D.
Ilmselt keegi neist aitab sind http://www.volkswagenag.com/content/vwc ... ement.html" onclick="window.open(this.href);return false;
Kellelgil siin foorumiski oli G4, millel pagassi põhja katte all oleva varustuse embleemi peal TDI GTI, ehk siis tegu pole mingi GTI bensiinika embleemi tagaluugile liimimisega ega vastavate lisavidinate juurde kruvimisega....asi veeres ikka tehasest välja.
Aga tõnn, teinekord võib ka kõige uskumatum osutuda tõeks. Aga kui pea ikka kivikõva, siis jõudu peaga vastu seina jooksmisega :lol:
copilot kirjutas:Kellelgil siin foorumiski oli G4, millel pagassi põhja katte all oleva varustuse embleemi peal TDI GTI, ehk siis tegu pole mingi GTI bensiinika embleemi tagaluugile liimimisega ega vastavate lisavidinate juurde kruvimisega....asi veeres ikka tehasest välja.
Stollu
t6nis3 kirjutas:Lehekülg ei ole poolik. Konkreetne. Seal mainitud üks GTI. G4 1,8 T.
on küll poolik , kui oleks konkreetne oleks valikus Vw Bora Variant 1.8T 132kw , seal aga variant 110kw ja järgmine 150kw , nii et sa ei jaga ikka mütsigi
