golf 3 näidikud TEEMA LUKKU
2rni
Auto: golf 3
Lugemata postitus Postitas 2rni »
ostsin endale golf 3 ja leidsin siis sellise asja https://www.youtube.com/watch?v=ulw8H0vUWXc" onclick="window.open(this.href);return false; , mida need 7 erinevat asja on, 7 on digitaalne tahhomeeter aga ülejäänud ?
Viimati muutis 2rni, 28 Sept 2014, 13:45, muudetud 1 kord kokku.
status
Telefon: 56788327
Auto: vento 66kw, passat b5 81kw
Re: golf 3 näidikud
Lugemata postitus Postitas status »
1= Distance Impulse number - the number of speedo sender pulses required to +1 the odometer. for miles the number is in the 6000 range, for kilometers the number is in the 3000 range.
2 = Clock display mode - 1: Europe (24 hour time) 2: Canada? 3. UK (12 hour) 4. USA (12 hour) 5. South Africa?
3 = Speedometer and rev. counter code
4 = number of cylinders, or ratio for alternator/engine revolutions. (for tach calibration)
5 = Segment test (lights all LCD segments)
6 = Speedomenter sender impulses - each wheel revolution adds 7 to this count.
8 = program version
2rni
Auto: golf 3
Re: golf 3 näidikud
oleks hea, kui saaks eesti keeles aru, muidu liiga keerulina :D
