Tööjuures ühel Tiguanil lõi mootoritule põlema. Käis esinduses, pandi arvuti taha ja öeldi, et vahetust vajab sisselaske kollektor. Aga miks või mida, seda ei täpsustatud.
Lugesin tal täna veakoodid ära ja palun targemate arvamusi nendele koodidele.
Tuesday,11,October,2016,10:45:06:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
http://www.Ross-Tech.com" onclick="window.open(this.href);return false;
VIN: WVGZZZ5NZ8W054098 License Plate: RAINER
Mileage: 150340km-93416mi Repair Order:
Chassis Type: 5N (1K0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 22 25 37 42 44 46 47 4F 52
53 55 56 62 69 6C 72 77
VIN: WVGZZZ5NZ8W054098 Mileage: 150340km-93416miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 G HW: 03L 906 022 G
Component: R4 2,0L EDC G000AG 2526
Revision: --H01--- Serial number: VWX7Z0H43N700W
Coding: 0000175
Shop #: WSC 83968 802 591622
VCID: 295E658B80EA85762A-807C
1 Fault Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 149921 km
Time Indication: 0
Date: 2000.00.00
Time: 16:33:49
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.78 V
Lambda: 99.4 %
Lambda: 4.7 %
Lambda: 11.8 %
Bin. Bits: 00000000
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09G 927 750 FD HW: 09G 927 750 FD
Component: AQ 250 6F 1124
Revision: 00H76000 Serial number:
Coding: 0000328
Shop #: WSC 01324 785 00200
VCID: 78F870CF0BC0ECFE65-802C
No fault code found.
Address 03: ABS Brakes Labels: 5N0-614-517.lbl
Part No SW: 5N0 614 517 L HW: 5N0 614 517 L
Component: J104 C2 450 V2 0006
Revision: --H11--- Serial number: 00000001089776
Coding: 0010530
Shop #: WSC 39951 136 61900
VCID: 377AB3F3465E2386AC-8062
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 DG HW: 1K0 907 044 DG
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6FEA4B937E8EAB46B4-803A
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 1T0 919 475 B HW: 1T0 919 475
Component: PARKHILFE PLA H07 0006
Revision: -------- Serial number: 22030810800775
Coding: 210103
VCID: 3A7CAAC7B54C3EEE53-806E
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__201 VW10 HI 1815
Revision: 19013000 Serial number: 0039BP7X6KM7
Coding: 0012337
VCID: 7AFC6AC735CCFEEE13-802E
Subsystem 1 - Serial number: 6333FTS606650948
Subsystem 2 - Serial number: 6343FTS622111158
Subsystem 3 - Serial number: 6353ETS6I36ATVNP
Subsystem 4 - Serial number: 6363ETS6SELATVNH
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0101
Coding: 0012022
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 5N0 920 870 D HW: 5N0 920 870 D
Component: KOMBIINSTRUMENT VDD 2420
Revision: V0004000 Serial number: VWX7Z0H43N700W
Coding: 0007104
Shop #: WSC 10660 002 1048576
VCID: 316E8DEBA83AFDB6E2-8064
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 5K0 963 272 E
Component: Standheizer 042 4709
Revision: 00042000 Serial number: 09021534000000
Coding: 0011012
Shop #: WSC 44440 136 90652
VCID: 326C82E7AD3CC6AE9B-8066
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AE HW: 1K0 907 951
Component: J533 Gateway H06 0111
Revision: H06 01 Serial number: 200809F1001846
Coding: FDA37F46504E03006002
VCID: 6ADC5A87456C4E6EE3-803E
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0AY 907 554 D HW: 0AY 907 554 D
Component: Haldex 4Motion 0042
Coding: 0000005
VCID: 4C90FC1F2FD8B05EF1-8018
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 2420
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 B HW: 1T0 035 680 A
Component: RNS-MID H04 1200
Revision: AB001001 Serial number: VWZ6Z7H9125008
Coding: 020500000100000200
VCID: 2D56919B74029956C6-8078
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 5N0 959 701 A HW: 5N0 959 701 A
Component: Tuer-SG 006 1205
Coding: 0000190
VCID: 336287E35226CFA690-8066
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.0 1002
Revision: 1AH03835 Serial number: 00111810076501
Coding: 0000258
VCID: 3C70ACDF7F7800DE41-8068
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0205
Revision: 00020000 Serial number: 00000000000000
Coding: 01800A0052830C7F3F04840570084FCEF0FC00
VCID: 030217234206BF2640-8056
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
2 Faults Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 58
Reset counter: 34
Mileage: 149921 km
Time Indication: 0
Date: 2000.00.00
Time: 16:35:48
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 4
Fault Frequency: 157
Reset counter: 238
Mileage: 149922 km
Time Indication: 0
Date: 2000.00.00
Time: 16:39:45
Address 47: Sound System Labels: None
Part No SW: 5N0 035 466 HW: 5N0 035 466
Component: DSP 10 Kanal 0002
Revision: 00002000 Serial number: 00000000002975
VCID: 6BD25F834A96576698-803E
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 1K0 907 951
Component: EZE_2 H06 0111
Coding: 05000000
VCID: 66C42EB791746A0EC7-8032
Subsystem 1 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Subsystem 2 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J394EE16SKB10 H01 0180
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 5N0 959 702 A HW: 5N0 959 702 A
Coding: 0000190
VCID: 346084FF5728C89E89-8060
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 5N0 907 801 B HW: 5N0 907 801 B
Component: J540 EPB3 VW-09384 0005
Revision: H08 Serial number: 00000000060949
Coding: 0000057
VCID: 2E549697B904E24EFF-807A
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 B HW: 5M0 907 357 B
Component: AFS-Steuergeraet X024
Revision: 00H01000 Serial number:
Coding: 1361158
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l S002
Coding: 00000020
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r S002
Coding: 00000020
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5N0 959 703 HW: 5N0 959 703
Component: Tuer-SG 006 1301
Coding: 0000144
Shop #: WSC 01324 785 1012552
VCID: 74E044FF17A8889E49-8020
Address 69: Trailer
Cannot be reached
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 5N0 907 441 HW: 5N0 907 441
Component: J772__Rearview 0021
Revision: 00H05000 Serial number: PA8 J840596
Coding: 0000010
VCID: 6CD05C9F4F98505E91-8038
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5N0 959 704 HW: 5N0 959 704
Coding: 0000144
VCID: 75E679FB1CD291967E-8020
Address 77: Telephone Labels: 3C0-035-729.lbl
Part No SW: 3C0 035 729 G HW: 3C0 035 729 G
Component: Telefon 7609
Revision: 00012000 Serial number: 0000B6A096798
Coding: 0016041
VCID: 275A63B396FEB3063C-8072
1 Fault Found:
00992 - Consumption Cut-Off Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 249
Mileage: 150345 km
Time Indication: 0
Date: 2000.00.00
Time: 10:41:56
End-------------------------(Elapsed Time: 03:51)--------------------------
K: Tiguani veakoodid
Re: K: Tiguani veakoodid
Esindus ei valetanud, vajab tõesti vahetust.
Sisselaskes olevad pöördsiibrid on kulunud. Liiguvad juba veidi rohkem tagasi kui peaks ja siibrite mootoris olev asendi andur tuvastab selle ja loeb veaks.
Põhimõtteliselt on võimalik teha hoovale piiraja ja asi hakkab tööle, aga siis ei tea keegi millal on nii kulunud, et tulevad pesast välja.
M.O.T.T
- TiitRE
- Tänanud: 59 korda
- Tänatud: 93 korda
Aga kas seal sama asja ei saa rakendada, nagu V6 tdi puhul, et eemaldada siibrid üldse? Pakutakse ju e-bays neid juba eemaldatud siibritega kollektoreid neile...kas ka 2.0tdi-le?Laur kirjutas:Esindus ei valetanud, vajab tõesti vahetust.
Samas lugesin üht välismaa foorumit ja sealne tegelane vahetas vist need klapid välja ja viga püsis - tegelik elu oli isolatsiooni kaotanud juhtmestik.
Seal käidud?
http://wiki.ross-tech.com/wiki/index.ph ... 015/008213" onclick="window.open(this.href);return false;
Special Notes
In some Cases the Issue can only be resolved by Replacing the whole Intake Manifold.
The Intake Manifold Flap Motor (V157) and Manifold Runner Position Sensor (G336) may be Part of the same Unit.
Special Notes
