Mure järgmine. Sai vahetatud roolilint, kuna põles airbagi tuli. Peale vahetust airbagi tuli kustus,aga põlema hakkasid esp/abs tuli ja sõidu aeg vilkuma punane piduri tuli. Üritasime kalibreerida rooli, ja uuesti softi panna,aga näitab et, VCDS reconnect's to ABS , ja näitab soft koodi 00000 & wsc 00000
ühesõnaga sama teema,mis siin kirjeldatud. Mootor sama. Autoks ise Passat B5,2003a 96kw ,1.9 diisel
I need to reprogramm my car's ABS/ESP module and set steering wheel angle. I try , but something is wrong.
My car is :
Audi A6(c5) Avant
2002 year
1.9 TDI ( engine code AWX 96kw/130hp.)
Manual gearbox
ABS modul is Bosch ESP 5.7
4B0 614 517 G
And brake typ is 1 LB
That's how I try :
1) Switch ignition On
2) Connect the VCDS to my car
3) Go to ABS Brakes
4) Then I go to this link http://wiki.ross-tech.com/wiki/index.ph ... S6/allroad_(4B" onclick="window.open(this.href);return false;)
5) There I select my type car , than [03] - brake electronics & than Bosch 5.7
6) There is nummbers I need , if I understand it correctly I need Login 07555 & Coding 06255. Correct ?
7) Than back in VCDS I select Login and enter 07555
And right now my problems begin
VCDS reconnect's to ABS , than it shows that soft coding is 00000 & wsc 00000
And nothing happens.
Can anybody explain what I doing wrong , why I can't reprogram ABS ?
On kellegil sama mure olnud siin. Ehk oskab nõu anda.
