Veakoodide tähendused ja info diagnostikateenuse pakkujatest
firekeeper
Tänanud: 0
Tänatud: 0
Re: Veakoodide tähendused ja info diagnostikateenuse pakkujatest
Lugemata postitus Postitas firekeeper » 21 Nov 2015, 13:00
Tervitus
Kas keegi saaremaal ka diagnosti teeb peale esinduse?
Vincento
Auto: 2021 VW Tiguan Life 1.5 110kw
Lugemata postitus Postitas Vincento » 17 Jaan 2016, 11:26
Soovin abi veakoodide tähendusel ja võimalikul remondil:
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CS HW: 3C0 907 044 CS
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 74FECB538EBBDAA20BE82A5-8020
2 Faults Found:
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 241
Mileage: 220474 km
Time Indication: 0
Date: 2016.01.14
Time: 18:44:23
01809 - Actuating Motor for Temperature Flap; Left (V158)
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 33
Mileage: 220545 km
Time Indication: 0
Date: 2016.01.16
Time: 20:04:54
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007855412
Coding: EF8A8F4701041A00470A00000F000000000B5D435C000100000000000000
Shop #: WSC 05124 000 00000
VCID: 71F0C247F1A9EF8AE00E0B9-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 181007 003 0205
Coding: 00046997
Shop #: WSC 05124
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 281107 046 0204
Coding: 00217165
Shop #: WSC 05124
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 19
Reset counter: 252
Mileage: 220515 km
Time Indication: 0
Date: 2016.01.15
Time: 15:50:00
Freeze Frame:
ON
Voltage: 11.95 V
ON
ON
OFF
OFF
OFF
Address 18: Aux. Heat
Cannot be reached
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P07B280AF3
Coding: FD81FF0E526E022002
Shop #: WSC 05311 000 00000
VCID: 235CF80F7BD50D1A2202511-8076
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 68
Mileage: 214410 km
Time Indication: 0
Date: 2015.10.16
Time: 13:32:55
volkar
Auto: Passat B6
Tänanud: 37 korda
Tänatud: 34 korda
Lugemata postitus Postitas volkar » 17 Jaan 2016, 18:02
Vincento kirjutas:Soovin abi veakoodide tähendusel ja võimalikul remondil:
Sellised vead võivad tekkida kui weba kaitsmed välja võetud.
kustuta ära ja vaata, kas tulevad tagasi
geike
Auto: Passat 1.9 81 kw 98
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas geike » 31 Jaan 2016, 14:23
Paluks abi selliste veakoodidega
65535-Internal Control Module Memory Error
00522-Engine Coolant Temp. Sensor (G62): Break in wiring / short circuit to Positive
Autoks siis passat 1.9 81 kw
tlauri
Tänanud: 0
Tänatud: 24 korda
Lugemata postitus Postitas tlauri » 31 Jaan 2016, 14:50
raidos
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas raidos » 01 Veebr 2016, 01:16
2.0 96kW ALT
Vea saan peale kustutamist järgmisel või ülejärgmisel soojalt käivitamisel.
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 008 - Implausible Signal
Mul on selle näidud VAG-COM logide graafikute järgi täiesti ootuspärased. Vea lööb sisse soojalt käivitades, kuigi loetud näit on sel hetkel täiesti reaalne. Mitmed külmstardi katsed 0C - 99C pole graafikutes anomaaliaid tekitanud. Samas paneb mõtlema, et kas radiaatoris olev temperatuurianduri G83 näit peab täiesti muutumatu olema (näiteks konstantselt +2C) kuni termostaadi avanemiseni? Vahepeal isegi +-1C ei kõigu 0C välistemperatuuri juures enne termostaadi rakendumist. Pärast avanemist hakkab tasapisi ka radiaatori näit kerkima ootustpäraselt. Status cooling koodid erinevatel katsetel vastavad täpselt olukorrale.
Vaatasin ka G62 juhtmestikku ning uurisin pistikut, probleeme ei täheldanud. Samuti liigub igati ootuspärases rütmis temperatuurinäidik armatuuris.
Kas keegi julgeb kinnitada, et temperatuuriandur võib ka niiviisi vigane olla, et probleem esineb korraks ja VAG-COM logimine ei püüa seda kinni?
EDIT: Ise kinnitan, et see on tõesti võimalik. Peale vana originaalosa vahetust uue (059919501A) vastu probleem kadus.
Viimati muutis raidos, 12 Veebr 2016, 17:29, muudetud 2 korda kokku.
tlauri
Tänanud: 0
Tänatud: 24 korda
Lugemata postitus Postitas tlauri » 01 Veebr 2016, 10:41
VAG-de tüüp-häda, et see andur "nühib ära" ennast ühest punktist ja siis tekib katkendlik töö. Saad testida, kui tõstad külma jahutusvedeliku taset anumas 2-3cm üle max joone. Kui seejärel kõik ok siis hakka vahetuse jaoks raha koguma. Uuri ise järgi, kas andur eraldi vahetatav või vaja koos uue reservuaariga. Vaesed ja laisad lisavad lihtsalt vedelikku ja jätavad remondi tulevikunagisse. Valik on sinu.
Dariusboy
Auto: 2002 Passat b5.5 1.9TDI 96kW
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas Dariusboy » 15 Apr 2016, 07:55
Tere hommikust.
Auto: VW Passat 2002 1.9 96kW manuaal esivedu mootor AVX
Mure:
ABS ja haarduvuse ( traction control ) lambikesed lähevad viimasel ajal väga tihti armatuuris põlema. Teine kord autot käivitades ning mõnikord lihtsalt pidurdades. Ära ei kustu sõidu ajal.
Vahetatud parempoolne abs andur ees, kuna sai viga käändmiku alt võttes.
Autot ostes, tegi müüja kiire diagnosti ning ütles, et võimalik probleemi allikas võib olla vasakpoolne abs andur, kuid polnud kindel. Andur siis eesmine.
Olen ise tartlane ning minu suur soov on see, et ehk mõnel tartu diagnostikul oleks laupäeval aega või siis täna peale 16.00 et korraks juhe taha visata ja öelda põhjus. Niisama jupide vahetusel ei näe mõtet.
Ette tänades
Martin
zenker
Telefon: 53338896
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas zenker » 06 Juun 2016, 16:21
Ei hakka uut teemat tegema.Nii ,et vabandused kui sai vale teema alla postitatud.Aga küsiks kas selline asi tasub osta ?
https://osta-ee.postimees.ee/vag-com-40 ... src=search" onclick="window.open(this.href);return false;
Vöi ei ole antud asjaga midagi eriti teha ?
Autoks 2000 a vw passat 1.9 tdi 85kw .
subwoof1
Telefon: 56979334
Auto: passat b3 syncro
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas subwoof1 » 07 Aug 2016, 18:21
Saan lugeda viljandimaal veakoode. 56681510
Vagcom
JanekT
Auto: Passat CC 3,6
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas JanekT » 15 Okt 2016, 18:59
Ehk keegi viitsib veits aidata
1 Fault Found:
012408 - Throttle Control
P3078 - 002 - Airflow at Idle too Low
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
3 Faults Found:
13635840 - Supply voltage
U1011 00 [000] - Voltage too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
13636608 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 152
Mileage: 152090 km
Date: 2016.09.21
Time: 21:36:01
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [000] - -
tlauri
Tänanud: 0
Tänatud: 24 korda
Lugemata postitus Postitas tlauri » 16 Okt 2016, 00:39
Selline hakitud moodulite nimekiri on niru, mille alusel asjasse peensustega süveneda. Kuvand jätab mulje, et generaatoriga on ilmselt mingi häda ja mingi mooduli kodeering on ilmselt seetõttu juhtumi tagajärg. Mõõteplokkide väärtused üle vaadata, vajadusel logida. Ilmselt 'basic settings' teha ning lõpuks haiget saanud moodul proovida kodeerida... kui ei õnnestu siis remontida/asendada. Kõigest täpsemalt RT lehel koos protseduuri juhistega.
JanekT
Auto: Passat CC 3,6
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas JanekT » 29 Okt 2016, 16:50
turday,29,October,2016,17:00:07:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
http://www.Ross-Tech.com" onclick="window.open(this.href);return false;
VIN: WVWZZZ3CZ9E502019 License Plate:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 22 25 2E 36 37 42 44 46
47 4F 52 53 55 56 5C 5D 62 65 69 72 77
VIN: WVWZZZ3CZ9E502019 Mileage: 153010km-95076miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
5C-Lane Maintain. -- Status: OK 0000
5D-Operations -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: Cannot be reached 1100
77-Telephone -- Status: Not registered 0011
Address 01: Engine (BWS) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 DQ HW: 03H 906 032 AB
Component: CC3.6-FSI-EU4 F 3490
Revision: 5GH04--- Serial number: VWZCZ000000000
Coding: 0000175
VCID: 74E7B6B6177A05E2B4-8020
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 012 D HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1804
Revision: 05144002 Serial number: 00001008262046
Coding: 0000020
Shop #: WSC 04940 001 00001
VCID: 1129DF2208A850CA3F-8044
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 Q HW: 3C0 614 109 Q
Component: J104 C4 440 V3 0011
Revision: --025--- Serial number: 00000785221149
Coding: 0024991
VCID: 2C576ED68FCA1D222C-8078
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 A HW: 5K0 907 044 A
Component: Climatronic 120 0202
Revision: 00002001
Coding: 0000000000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 295997C24838080AD7-807C
1 Fault Found:
13701536 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 152930 km
Date: 2016.10.27
Time: 19:33:59
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008238665
Coding: E7E68F8B00041A0047978F0017000000000BFB4764400165170000000000
Shop #: WSC 05124 123 12345
VCID: 336575AA52F442DA6D-8066
Subsystem 1 - Part No: 3C8 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 081207 022 0601
Coding: 00046997
Shop #: WSC 05124
Component: RLS 240408 046 0204
Coding: 00208933
Shop #: WSC 05124
2 Faults Found:
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 194
Mileage: 152887 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
02390 - Control / Regulation for Ambience Lighting (E400)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 194
Mileage: 152930 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 1T0 919 475 C HW: 1T0 919 475
Component: PARKHILFE PLA H07 0009
Revision: -------- Serial number: 61730810702138
Coding: 110107
Shop #: WSC 43997 001 00001
VCID: 3B755D8ABAA48A9AB5-806E
Address 13: Auto Dist. Reg Labels: 3C0-907-567.clb
Part No SW: 3C0 907 567 M HW: 3C0 907 567 J
Component: AC201 RDW A 031 0243
Revision: 00031000 Serial number: 00000000900937
Coding: 0010000
Shop #: WSC 00072 204 178846
VCID: 35614BB25C805CEA43-8060
Address 14: Susp. Elect. (J250) Labels: 3C0-907-376.clb
Part No SW: 3C0 907 376 HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0069
Revision: 00000000 Serial number: 21030800310002
Coding: 030180
Shop #: WSC 05314 000 00000
VCID: 66C3DCFE91A6E7723A-8032
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__308 VW10 HI 1815
Revision: 19013000 Serial number: 0039BP736S9F
Coding: 0012344
VCID: 7AFB988E351E7392EE-802E
Subsystem 1 - Serial number: 6333FTS643530808
Subsystem 2 - Serial number: 6343FTS607320798
Subsystem 3 - Serial number: 6353ETS64216TVNH
Subsystem 4 - Serial number: 6363ETS65366TVNP
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
Component: J0527 0025
Revision: 00029000 Serial number: 3C5953507CC
Coding: 0201821
Subsystem 1 - Part No: 3C8 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H1˙ 0020
Coding: 00000227
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 870 HW: 3C8 920 870
Component: KOMBI H19 0023
Coding: 140F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 68DFD2C693B2F10208-803C
Part No SW: 3C0 907 530 F HW: 3C0 907 951
Component: J533__Gateway H-- 0142
Revision: H-- Serial number: 2200
Coding: FDAFFF4750221B9002
Shop #: WSC 00019 204 97636
VCID: 244786F6E71AD562E4-8070
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 153011 km
Time Indication: 0
Date: 2011.03.22
Time: 16:54:31
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 194
Mileage: 153011 km
Time Indication: 0
Date: 2011.03.22
Time: 16:54:35
Address 22: AWD Labels: None
Part No SW: 0BS 907 554 HW: 0BS 907 554
Component: Haldex 4Motion 4011
Coding: 0000005
VCID: 0305E56A42D4325ABD-8056
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 799 H HW: 3C0 959 799 H
Component: IMMO 071 0383
Revision: 00071000 Serial number: VWZCZ000000000
Shop #: WSC 48356 141 90369
VCID: 3E73549E69B69FB292-806A
Subsystem 1 - Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 HW: 5N0 035 342
Component: SG EXT.PLAYER H08 0062
Revision: A1001003 Serial number: 7667003432
Coding: 010000
VCID: 64C7C6F6679A956224-8030
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 HW: 3C8 959 760
Component: J810 0801
Revision: 00002000 Serial number: 00000000000000
Coding: 0000001
VCID: 72EBB0AE6D6E0BD2A6-8026
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 B HW: 1T0 035 680 B
Component: RNS-MID H03 1200
Revision: AB001001 Serial number: VWZ6Z7H9175004
Coding: 04000400040000A200
VCID: 2D5163D274D0142A3B-8078
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1527
Revision: 71009005 Serial number: 00000064888214
Coding: 0004606
VCID: 408F2A661342E942E0-8014
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 G HW: 5N1 909 148 E
Component: J500__APA-BS KL.062 0401
Revision: 1AH01238 Serial number: 00080590082901
Coding: 0000258
VCID: 36634CBE418657F24A-8062
Address 46: Central Conv. Labels: 3C0-959-799-46.clb
Component: 09 KESSY PQ46 R 071 0231
Coding: 00910A0001C60E76360494157000CFCE70580103242498
Subsystem 1 - Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H08 9001
Subsystem 2 - Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Subsystem 3 - Part No: 3C0 951 171 C
Component: Innenraumueberw.004 0611
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No SW: 3C8 035 456 C HW: 3C8 035 456 C
Component: DSP 10 Kanal
Revision: 00H05001 Serial number: 75805000326102
VCID: 285F92C69B323102C8-807C
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 4F: Centr. Electr. II (J533_) Labels: 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 3C0 907 951
Revision: -------- Serial number: 2200
Coding: 01030101
Shop #: WSC 51585 020 1979139
Subsystem 1 - Part No SW: 6R0 959 591 HW: 6R0 959 591
Component: J245 H04 0043
Serial number: 751500002852
Coding: 000006
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1527
Revision: 71009005 Serial number: 00000510288212
Coding: 0004096
VCID: 41892F621848E04AEF-8014
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 008 Serial number: 00000000003667
Coding: 0000057
Shop #: WSC 05311 000 08193
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0133
Revision: 00H04000 Serial number:
Coding: 3525832
VCID: 346776B657FA45E274-8060
Subsystem 1 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0002
Coding: 00000053
Subsystem 2 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0002
Coding: 00000053
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 5C: Lane Maintain. Labels: 3C0-907-217.clb
Part No SW: 3C0 907 217 HW: 4E0 907 217 C
Component: J759 HCA 0100
Revision: 00H07008 Serial number: 80020831900017
Coding: 0032002
VCID: 60CFCAE6B3828942C0-8034
Address 5D: Operations Labels: 3C0-035-151.lbl
Part No SW: 3C0 035 151 C HW: 3C0 035 151 C
Component: J738 011 0019
Revision: 00011000
VCID: 183FA2062B52818278-804C
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 3C8 959 703 B HW: 1K0 959 795 Q
Component: J388 TUER-SG HL 0306
Revision: 43004101 Serial number: 00000000321482
Coding: 0000152
VCID: 31697FA2A8E870CA1F-8064
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0453
Coding: 0161210
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H07 0100
Revision: 3A001001 Serial number: 00000132725908
Coding: 0100000100000000
VCID: 306F7AA663E279C210-8064
Address 72: Door, Rear Right
Cannot be reached
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 A HW: 5K0 035 730 A
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007660534030
Coding: 0201000001010110
Shop #: WSC 00737 204 94822
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 234585EA2A14D25A9D-8076
1 Fault Found:
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 152
Mileage: 152090 km
Date: 2016.09.21
Time: 21:36:01
Parem tagumine uks oli tumm.Ainult ülemine kõlar tegi häält.
Ei toimi siis sellel uksel kesklukk,kõlar ja aken.Võtsin uksepolstri maha ja kontrollisin juhtmed üle,kahjustusi ei olnud.
Võtsin aknatüstuki küljest juhtmed korra ära ja hakkas toimima aga juhi ukse küljest ei toimi ikka.
tlauri
Tänanud: 0
Tänatud: 24 korda
Lugemata postitus Postitas tlauri » 29 Okt 2016, 17:28
Kanal 19 CAN Gateway 01044 - Control Module Incorrectly Coded
http://wiki.ross-tech.com/wiki/index.php/01044
Viimati muutis tlauri, 29 Okt 2016, 17:31, muudetud 1 kord kokku.
Tänatud: 75 korda
Lugemata postitus Postitas dellu » 29 Okt 2016, 22:09
JanekT kirjutas: Parem tagumine uks oli tumm.Ainult ülemine kõlar tegi häält.
Õhtut.
Selle Tlauri viidatud vea genereerisin ilmselt ka mina. Kuna sa väisid, et autos mingit telefoni pole, siis võtsin can-cateways telefoni eest linnukese ära. Pärast muidugi enam üle ei vaadanud. Kui muidugi meenutada, siis pärast telefoni moodul vastas, järelikult midagi seal ikkagi on, aga mingi osa on vigane ikkagi. Samas tagaukse probleem see ei ole. Sest minu logis on ju jällegi näha, et 19- can gateways oli enne ka telefonile viitav viga sees. See lihtsalt kadus nüüd ära ja asendus incorrectly coded veaga. Ehk can gateway ise ikkagi näeb, et telefoni moodul on olemas, aga tal ei ole linnukest. Sellest veast saab linnukesega uuesti lahti, aga siis tuleb jälle see vana viga tagasi.
Delvis
zellek
Auto: vw passat 3C 2.0TDI
Tänanud: 0
Tänatud: 0
Passat B6 Webasto
Lugemata postitus Postitas zellek » 05 Nov 2016, 18:56
Kes teab öelda?
Webasto taimeril lööb ette F07 ja ei käivitu.
masuurik
Auto: QUATTRO 5.
Tänanud: 0
Lugemata postitus Postitas masuurik » 08 Nov 2016, 21:19
Kirjutan küll valesse kohta, aga kuna siin oli väga palju rõõmsaid püsikliente katkiste autodega, siis
Nimi: Ott (Tallinn), kokkuleppel saame ka kujal toimetada.
Kontakt: 53417140, Privaatsõnum
Sõiduautodele: Audi, Volkswagen, Seat, Skoda
Aasta: Autodele aastast 1990 - 2016
Pakutav funktsioon: Veakoodide lugemine, kustutamine, auto elektroonikaga seonduv. Ehitan ka autode elektroonikat ise, modifitseerin tehase paigaldatut. Suudan teile teha elektroonikast vahvaid custom asju.
Tasu: alates 5 € diagnostika(2006 alates 10 eur) ja sealt edasi sõltuvalt tööst 10€...+
Kuna teen seda kõike hobi korras, siis ei püüa ma rikastuda.
Viimati muutis masuurik, 08 Nov 2016, 21:21, muudetud 1 kord kokku.
VWM
Auto: VW Passat B7 / 2.0 TDI 103kw /
Lugemata postitus Postitas VWM » 26 Jaan 2017, 17:20
9481988 - Air Quality Sensor
B10AF 04 [009] - Internal System Fault
Autoks VW passat b7, et kas sellise veaga tuleks hakata andurit vahetama? Ja kus see asuda võiks. Enne salongi tuleva õhuvõttu kuskil?
VWM
Lugemata postitus Postitas VWM » 26 Veebr 2017, 16:21
Kui see küsimus siia teema alla ei sobi siis moded võivad mujale sobivamasse kohta tõsta.
no eelmise probleemi kohta pole vastust saanud aga äkki nüüd saab miskit.
Et äkki keegi teab miks ei õnneustu Led numnritulesid tööle saada ilma veateateta?
Sai aktiveeritud " license Plate Light w/o Pulse Wigth Modulation (PWM) [LED Light] Byte 17 bit7
ja deakitiveeritud " Lamp Monitoring (Gold) Licence Plate Lamps active" Byte 23 bit6.
koodi acceptis ilusti aga ikka viskab viga. Miskit, kuskil jääb kahe silma vahele?
Tegu siis vw originaal led numbri tuledega.
Skype: magnake
Tänanud: 48 korda
Tänatud: 229 korda
Lugemata postitus Postitas R36 » 26 Veebr 2017, 16:44
Sest byte18 on pigem vastutav selle eest.
Cold diagnostic on ainult mittepõlev kontroll, hot diagnostic on ikka peal. PWM on lihtsalt toite kuju.
VWM
Lugemata postitus Postitas VWM » 26 Veebr 2017, 16:50
ok.. lähen veidi aja pärast uurima.
Edit: byte 18 all on näha ainult bit 0-7 "00 light setup: standard/parameter settings (eeprom).
Muid valikuid pole ka. Et kas on mingi võimalus need tööle saada?
lugedes neid teemasid, siis mul jääb teadistest puudu ja ega lihtsam oleks ka takistitega jamada.
http://forums.vwvortex.com/showthread.p ... oday/page2
http://forums.vwvortex.com/showthread.p ... st67300665
deiv0
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas deiv0 » 08 Mär 2017, 10:10
Keegi oskab öelda mis veaga on tegu?
pwoap
Auto: Golf IV ; Passat CC
Tänatud: 0
Lugemata postitus Postitas pwoap » 30 Apr 2017, 09:24
Kas kellegil on kogemust ELM327 OBD II Bluetooth mooduliga, mis väidetavalt peaks (16-pin DLC) OBD II pistikusse ühenduma ja reaalajas multimeedia seadmesse läbi bluetoothi auto töö perimeetreid saatma ja sh ka lugeda veakoode ja vajadusel neid kustutada. Kas selline adapter reaalselt töötab ka ?
link:
http://www.autodigi.ee/epood/OBD-II-Blu ... -raadiole/
tlauri
Tänanud: 0
Tänatud: 24 korda
Lugemata postitus Postitas tlauri » 30 Apr 2017, 09:53
See ei ole audentne ja täisvereline ELM327 ning see ei tööta kõikidel nendel loetletud protokollidel. Ainult osad lihtsamad protokollid on toetatud, mis uuematel autodel.
Õige ELM327 maksab oluliselt rohkem. ELM327 audentsust saab testida näiteks äppiga. Android jaoks näiteks ELM327 Identifier vabalt saada.
zellek
Tänanud: 0
Tänatud: 0
Lugemata postitus Postitas zellek » 21 Mai 2017, 20:13
Viimati muutis zellek, 06 Juul 2017, 21:34, muudetud 1 kord kokku.
