Lasin puhtaks jah. Nüüd jõudsin tuppa just ja hoidsin akujuhet maas tund aega (eelmine kord vast 10 min.) ja nüüd oleks nagu suhtlus tagasi? Ainukesena särab hetkel rooliasendi andur, kuna juhe oli maas.
Friday,03,August,2018,21:06:52:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: WVWZZZ1KZ8M027041 License Plate:
Mileage: 285000km-177090mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ8M027041 Mileage: 285000km-177090miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 PM HW: 03G 906 021 AN
Component: R4 1,9L EDC G000AG 1136
Revision: --H07--- Serial number: VWX7Z0G624V04R
Coding: 0000078
Shop #: WSC 00066 000 00000
VCID: 79FE75CB30CAF5F61A-802C
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 044 G HW: 02E 927 770 AE
Component: GSG DSG 081 1404
Revision: 04608010 Serial number: 00000706110019
Coding: 0000020
VCID: 193E554BD08A15F6BA-804C
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F8ADBD36E6E1BC664-806A
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000000695822
Coding: ED038E2700041500470A00000F00000000095D035C000100000000000000
VCID: 71EE4DEB68BABDB6A2-8024
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 060807 020 0501
Coding: 00038805
Shop #: WSC 00066
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 220607 020 0105
Coding: 00208933
Shop #: WSC 00066
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 2J AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0X8BV3
Coding: 0012874
Shop #: WSC 00857 461 21557
VCID: 3D76A1DB646209D676-8068
Subsystem 1 - Serial number: 6332MSME23004B685
Subsystem 2 - Serial number: 6342MSME145C1959I
Subsystem 3 - Serial number: 6351HSME0F2F733CO
Subsystem 4 - Serial number: 6361HSME0F305A0CD
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0012121
VCID: 010E1D2B581AAD3652-8054
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 874 B HW: 1K0 920 874 B
Component: KOMBIINSTRUMENT 3HL 1216
Revision: V0002000 Serial number: VWX7Z0G624V04R
Coding: 0023103
Shop #: WSC 00011 888 96745
VCID: 2C509C9F8F18905ED1-8078
Coding: 0023103
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 250607F2002031
Coding: ED807F060002021002
VCID: 306888EFA330F4BEED-8064
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1216
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1133
Revision: 32008001 Serial number: 00000566278718
Coding: 0000180
VCID: 3B72AFC37A7607E648-806E
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.070 H08 1901
Shop #: WSC 02069 000 90108
VCID: 3566B9FB5C52D196BE-8060
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 81900A0001060C7F2D04840570084FC6F0FC00
VCID: 030217234206BF2640-8056
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1133
Revision: 32008001 Serial number: 00000027278718
Coding: 0000180
VCID: 3C70ACDF7F7800DE41-8068
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 186 AD HW: 1K0 035 186 AD
Component: Radio BVX 034 0046
Revision: 00034000 Serial number: VWZ1Z2G4794567
Coding: 0040400
VCID: 68D8208F5B607C7EF5-803C
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1120
Revision: 11006001 Serial number: 00000001944794
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1120
Revision: 11006001 Serial number: 00000001949835
Coding: 0000144
VCID: 3E74A6D7696412CE6F-806A
End-------------------------(Elapsed Time: 02:19)--------------------------
