Mure järgmine: kiirusel 90+ kadus jõud. Sõitsin tee äärde, suretasin auto välja. Käivitamine võttis kauem kui tavaliselt ja pöörded enam üle 3000 ei lähe. Varem polemingeid anomaaliaid olnud. Arvuti tuvastas sellised veateated. Äkki kellegil on sarnast kogemust?
Tänud ette.
Address 01: Engine ( ) Labels: 06J-907-115-BZB.clb
Part No SW: 06J 906 026 HW: 06J 906 026
Component: MED17.5 1756
Revision: A8H03--- Serial number: VWZCZ000000000
Coding: 0404000318070160
Shop #: WSC 05314 000 00000
VCID: E7D93FAFAA49
6 Faults Found:
001056 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Mileage: 184240 km
Time Indication: 0
Date: 2000.00.00
Time: 11:06:22
Freeze Frame:
RPM: 2177 /min
Load: 29.0 %
Speed: 96.0 km/h
Temperature: 97.0°C
Temperature: 33.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.097 V
000369 - Fuel Trim; Bank 1: System Too Lean
P0171 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 183235 km
Time Indication: 0
Date: 2000.00.00
Time: 15:52:59
Freeze Frame:
RPM: 838 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 51.0°C
Voltage: 13.589 V
008851 - Fuel Pressure Regulator Valve (N276): Mechanical Malfunction
P2293 - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 184528 km
Time Indication: 0
Date: 2000.00.00
Time: 08:51:20
Freeze Frame:
RPM: 2728 /min
Load: 27.4 %
Speed: 100.0 km/h
Temperature: 96.0°C
Temperature: 34.0°C
Voltage: 14.097 V
000290 - Throttle Position Sensor (G69): Signal too Low
P0122 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 0
Date: 2111.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 68.0°C
Temperature: 44.0°C
Voltage: 12.065 V
000546 - Angle Sensor 2 for Throttle (G188): Signal Too Low
P0222 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 0
Date: 2111.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 68.0°C
Temperature: 44.0°C
Voltage: 12.065 V
005464 - Throttle Actuator (G186): Electrical Malfunction
P1558 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 184664 km
Time Indication: 0
Date: 2000.00.00
Time: 15:21:54
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 68.0°C
Temperature: 44.0°C
Voltage: 12.192 V
Passat 2008 1,8TSI pöörded ei lähe üle 3000
Beluuga
- Telefon: 58383262
- Auto: Golf 4 2001 2,0 85 kw manuaal
Suur asjatundja pole aga nii puusalt tulistades tunduvad sul pooled probleemid laadimisega olema juba. Kas se nüüd mootori tüüd ka segab ma ei oska kinnitada .
Hommikul panin uuesti arvuti järgi, kustutasin veateated ära. Tagasi tuli ainult 008851 kõrgsurve klapi kohta.
- Tänanud: 99 korda
- Tänatud: 193 korda
Mis laadimis anomaaliat siit taga ajate - hetkel kui pardapinge on 12.xx V mootor ju seisab ning töötava mootoriga on laadimine 13,6...14,0V.
