Vw Golf V Raadio/Navi probleem
Erx666
Lugemata postitus Postitas Erx666 »
Sai omale soetatud Vw Golf 5 GT Sport. Autol on peal originaal radio/navi RNS510 tehase koodiga 1T0 035 680 A
Järgmine päev hakkas pull raadioga peale. Paned auto tööle raadiol tuleb pilt ette, aga kõlaritest muusikat ei tule ja ükski nupp ei funktioneeri.
Kui teha raadiole mitu resetti. (mõni kord 1 , mõni kord 10) siis hakkab raadio ilusti tööle. Raadio mängib umbes pool tundi ja viskab pildi taskusse.
Paned nupust tööle ja jälle mängib. (resette vaja teha pole). Auto seisab mõne aja , lähed autosse ja radio jälle ei toimi.
Vaatasin siis auto lisavarustuse nimekirja ja sealt välja ei jookse ,et oleks Navi paigaldatud tehase poolt. Ilmselt siis järelpaigaldatud.
Auto lisavarustus:
B0A = Component parts set without country-specific design requirement
CX8 = Alloy wheels 7J x 17
G1A = 6-speed automatic transmission
H6L = Tires 225/45 R17 91W
J1D = Battery 380 A (72 Ah)
D4P = 4-cyl. gasoline engine 1.4 L/125 kW 16V TSI TC with compressor and turbocharger Base engine is TF0
1AS = Electronic stabilization program (ESP)
1G6 = Space-saving spare wheel
1MH = Leather steering wheel
1NL = Covers for alloy wheels
5RQ = Right exterior mirror: convex
5SL = Left exterior mirror: aspherical
TF0 = 4-cylinder gasoline engine 1.4 L unit 03C.H (aluminum)
0BE = Rear stabilizer
3S0 = Without roof rails/roof load rack
3U1 = Foldable trunk cover
QG1 = Service interval prolongation
8AY = Radio/navigation system
8GG = Alternator 110 A
8ZN = Antenna
1KD = Disc brakes, rear
1LJ = Disc brakes, front
3YR = Door pockets with insert mats
G07 = Front shock absorption
0GG = Emission standard EU4
0Y3 = Cold zones
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
4X3 = Side air bag front with curtain air bag
4R4 = Power windows with comfort operation andcircuit breaker
4K3 = Radio remote controlled central locking operated from inside and safe securing
N0E = Woven fabric seat covering
5MN = Decorative inserts
8RW = 10 speakers (passive)
2JG = Body-colored bumpers
E04 = "Wolfsburg Edition"
0AE = Front stabilizer
2UC = Sports version
2G7 = Filler neck module 1 with insert
1JC = Rear shock absorption for sports design
L58 = Suspension range 58 installation control only, no requirement forecast
0YB = Weight range 2 installation control only, no requirement forecast
Panin siis autole diagnostika seadme külge ja leiab mitmeid vigu.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BF HW: 1K0 953 549 BF
Component: J0527 051 0100
Coding: 0010012
Shop #: WSC 01392 785 00200
VCID: 77FD0D5706389FA6A59-8022
5 Faults Found:
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K0821407AF
Coding: ED807F064002020002
Shop #: WSC 00856 461 174443
VCID: 306FF64BA3D6889E243-8065
3 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 200
Mileage: 111547 km
Time Indication: 0
Date: 2000.00.00
Time: 19:20:44
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 200
Mileage: 111547 km
Time Indication: 0
Date: 2000.00.00
Time: 19:20:49
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 200
Mileage: 111547 km
Time Indication: 0
Date: 2000.00.00
Time: 19:20:49
Address 37: Navigation
Cannot be reached
Address 56: Radio
Cannot be reached
Tundub ,et auto ei saa ühendust raadio/naviga.
Võtsin raadio välja ja seal tundus kõik ilusti ühendatud olevat.
Samuti peab raadiot kinni ja käima panema eraldi nupust. Võtme süütelukku panekuga või välja võtmisega raadio ei käivitu ega lähe kinni.
Kas keegi tark oskaks öelda milles võib probleem olla ja kuidas selle ühendatud saaks?
Tänatud: 604 korda
A mis rida see siis on: 8AY = Radio/navigation system
argo
Foorumi arendaja
Tänanud: 82 korda
Tänatud: 51 korda
Lisa?
PiltPiltPilt
Erx666
jussike kirjutas: 03 Nov 2018, 16:12 A mis rida see siis on: 8AY = Radio/navigation system
Hmmm... ma ei pannud kohe kiire pilguga seda tähele.
Tundub siis ikkagi ,et on tehase poolt paigaldatud. Aga miks ta siis raadiot ja navi üles ei leia? Eeldan , et tehasest lahkudes auto moodulid ikka ilust seadistatud?
Tänatud: 604 korda
Ei ole küll kõige pädevam ütlema, aga tundub, et CAN Cateway plokiga või siis naviga endaga miskit juhtunud. Kuula ära mida levwfreaksidel öelda on.
Tänatud: 203 korda
Eks see Ver.A üks kehvake ole. Siis kui see uuena tuli vahetati mitmeid garantiikorras välja. Meil ei tea, kuid väljamaal palju juhtumeid. Samuti läbi Leedu mitmeid RNS-e näinud, mis maha kantud, kuid kuidagi uuesti ringlusesse lastud. Üritades PIN koodi lugeda ODIS-ga ütleb VW, et mahakantud makk.
Igatahes antud juhul ilmselt emaplaadil komponendid surnud/suremas. CAN ahel ei saa maki protsessoriga ühendust ja siis ei oska makk midagi teha, kui etteantud 30min mängida ja siis välja lülitada. Sama teeks korras makk, kui lauapeal käima panna. Võib proovida üle joota, kuid on olnud üks õnnetu juhtum, kus peale emaplaadi eemaldust ja taaspaigaldust makk enam pilti ette ei võtnud.
Erx666
R36 kirjutas: 03 Nov 2018, 21:48 Eks see Ver.A üks kehvake ole. Siis kui see uuena tuli vahetati mitmeid garantiikorras välja. Meil ei tea, kuid väljamaal palju juhtumeid. Samuti läbi Leedu mitmeid RNS-e näinud, mis maha kantud, kuid kuidagi uuesti ringlusesse lastud. Üritades PIN koodi lugeda ODIS-ga ütleb VW, et mahakantud makk.
Ühesõnaga oleks ilmselt kõige mõistlikum mingit teist makki proovida ja vaadata mis siis toimub !?
Erx666
Viskasin raadiod ringi. Teine RNS510 raadio toimetab ilusti.
Kas seda RNS510 tehase koodiga 1T0 035 680 A saab üldse remontida ja kas tasub?
Ja ehk oskate kedagi soovitada ka?
Või äkki aitab tarkvara uuendus? Ei usu väga ,et keegi seal firmware uuendanud oleks.
Tänatud: 604 korda
Remontida vast ikka saab, aga kas on mõtet, pigem sobib elundi doonoriks.
Tänatud: 203 korda
jussike kirjutas: 04 Nov 2018, 13:02 Remontida vast ikka saab, aga kas on mõtet, pigem sobib elundi doonoriks.
Võib ju proovida aga nagu ütlesin, siis garanteerida ei saa.
Erx666
Mõtlen ,et prooviks veel tarkvara uuenduse ära aga siin kohal tekib kohe mitu probleemi.
Proovisin minna radio hidden menu-sse aga seal ei olnud kohta kust näeks ära mis versioon seal peal on.
Nüüd nagu ei teagi mis firmware sinna peale lasta. Kõige kindlam vist oleks firmware 5238 ?
Teine probleem on kohe see ,et raadio ju lülitab ennast umbes 30min pärast välja. Kas ta teeb seda ka siis kui firmware uuendan? Väidetavalt pidi firmware intalleerimine võtma umbes 1h :)
Erx666
R36 kirjutas: 04 Nov 2018, 13:04
Mis selline ehku peale remont maksma läheks?
