Nimelt sai siis oma Superbile kaabel taha pandud, kuna tahtsin teada miks ei tööta footwell lights aga selgus ka muid probleeme millega tahaks tegeleda. Kuna Skoda oma foorum on suht surnud, ja sealt mingeid vastuseid ei saa siis prooviks siit.
Masin aastast 2009 ja mootoriks 2.0 103kW.
Chassis Type: 3T (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 42 44 46 52 56 62 72
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 QP    HW: 03G 906 021 AB
   Component: R4 2,0L EDC G000AG  2893
   Revision: --H09---    Serial number:
   Coding: 0000078
   Shop #: WSC 33361 790 00000
   VCID: 7DF789B6248604F6F0B-8028
No fault code found.
Readiness: 0 0 0 0 0
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 AF    HW: 3T0 907 044 AF
   Component: Climatronic   122 0203
   Revision: 00003001
   Coding: 0100000000
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 76E5969AC9B057AEB11-8023
3 Faults Found:
9474417 - Motor for Front Air Distribution Flap
          B1091 71 [008] - Actuator stuck
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 198
                    Mileage: 287195 km
                    Date: 2107.14.14
                    Time: 17:57:13
9474418 - Motor for Front Air Distribution Flap
          B1091 54 [009] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 289850 km
                    Date: 2108.14.07
                    Time: 12:26:04
9481988 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
             Freeze Frame:
                    Fault Priority: 3
                    Reset counter: 158
                    Mileage: 287194 km
                    Date: 2107.14.14
                    Time: 15:46:57
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 A    HW: 1K0 937 086 A
   Component: BCM PQ35  M+  020 0358
   Revision: 00020000
   Coding: 40990AB8D80508C040080084110081A405711BAE432081605C4040000000
   VCID: 2E557EFA79602F6E391-807B
   Subsystem 1 - Part No: 3T1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 14010  22  0602
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 190109 05  54  0402
   Coding: 0730ED
5 Faults Found:
00061 - Footwell Lights
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 5
                    Reset counter: 158
                    Mileage: 279572 km
                    Time Indication: 0
                    Date: 2040.14.08
                    Time: 18:35:43
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.55 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
02394 - Parking Light Left Front (M1)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 191
                    Mileage: 290772 km
                    Time Indication: 0
                    Date: 2044.14.30
                    Time: 14:50:11
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.05 V
                        ON
                        ON
                        Term 50 On
                        OFF
                        OFF
00985 - Right Tail Light (M2)
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 186
                    Mileage: 293798 km
                    Time Indication: 0
                    Date: 2046.14.25
                    Time: 19:27:17
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.40 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00979 - Lamp for Low Beam; Right (M31)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 4
                    Reset counter: 197
                    Mileage: 295160 km
                    Time Indication: 0
                    Date: 2047.14.16
                    Time: 18:30:05
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.70 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00978 - Lamp for Low Beam; Left (M29)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 197
                    Mileage: 295167 km
                    Time Indication: 0
                    Date: 2047.14.16
                    Time: 20:33:18
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.65 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 A    HW: 7N0 959 793 A
   Component: TSG FA        H03 0190
   Revision:             Serial number: 0000100629990
   Coding: 011D0220DE00121002
   VCID: 40893042D3F4A91EDBD-8015
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 3
                    Fault Frequency: 39
                    Reset counter: 131
                    Mileage: 277494 km
                    Time Indication: 0
                    Date: 2039.14.09
                    Time: 08:22:29
													[Škoda] Skoda Superb MK2 mõningad probleemid
Moderaatorid: HawkHill, argo, etnies858
				rainis1225
 - Uustulnuk
 - Auto: Golf III
					Viimati muutis argo, 25 Juul 2019, 21:22, muudetud 1 kord kokku.
