Äkki kellelgi kogemusi antud vigadega.
Tundubt, et ühendus ECM ja TCM'iga kadunud.
chassis Type: 1T (1K0)
Scan: 01 02 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ5W054688 Mileage: 309740km-192463miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021190
Shop #: WSC 07490 995 02915
VCID: 3A70FBBD757F24560C-806E
4 Faults Found:
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication - Intermittent
00474 - Control Module for Immobilizer
01314 - Engine Control Module
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 CR
Component: Climatic PQ35 081 0404
Shop #: WSC 00000 000 00000
VCID: 76E82F8D01E7803628-8022
1 Fault Found:
013 - Check DTC Memory
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 S HW: 1K0 937 049 S*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000001003887
Coding: 08890F020004100000120C000000000000
Shop #: WSC 10734 002 1048576
VCID: 3F868AA96E5D017E3B-806A
Subsystem 1 - Part No: 1T0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW358 012 0401
Coding: 00065493
Shop #: WSC 10734
2 Faults Found:
01064 - Terminal 58d; Interior Dimming
012 - Electrical Fault in Circuit
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD093015
Coding: 0012338
Shop #: WSC 01324 785 00200
VCID: 356AE8815C61CB2EE1-8060
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0010042
VCID: 3064D995A303EE06B2-8064
1 Fault Found:
00002 - Transmission Control Unit
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1T0 920 861 A
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0003103
Shop #: WSC 29693 001 1048576
2 Faults Found:
01315 - Transmission Control Module
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Revision: A Serial number: 09010046
Coding: 0000011
Shop #: WSC 52202 522 86524
VCID: 2A50CBFD85DF94D67C-807E
1 Fault Found:
02085 - Incorrect Control Module Installed
000 - -
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 27001048240935
Coding: 3F3F1340078002
VCID: 295234F180D99FCE75-807C
2 Faults Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 251
Mileage: 309745 km
Time Indication: 0
Date: 2000.00.00
Time: 02:52:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 251
Mileage: 309745 km
Time Indication: 0
Date: 2000.00.00
Time: 02:52:55
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 0814
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0157
Coding: 0000116
VCID: 74EC1585179B922616-8020
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.6 1401
VCID: 2F66DAE9BE3DF1FEAB-807A
2 Faults Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Mileage: 9720 km
Temperature: 11.0°C
Voltage: 11.30 V
Voltage: 11.20 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 88E802087F2D8404084F016011
VCID: 7BFE3EB93AC5DD5E57-802E
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000116
VCID: 75EA28811CE18B2E21-8020
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 L
Component: Radio BVX 010 0022
Coding: 0020200
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000048
touran 2,0 tdi DSG 2004a probleemid.
- siLc
- Auto: Passat B7 EcoFuel
- Tänatud: 154 korda
Annab...
Kui süüde sisse panna, siis kas kapotialuse kaitsmekarbis on vool peal kaitsmetel SB11, SB12 ? Kui pole, siis relee 458 (pildil A4) ei lülita.
Käigukasti osas SB13 ja relee 433 (pildil A1).
Viimati muutis siLc, 08 Mai 2020, 19:59, muudetud 2 korda kokku.
Wizard
- Auto: g4 variant `05
Sai siis proovitud ja masin töötab jälle.
Mootori poolest siis veaks relee aga käigukastil kaitse puudu. Kes võttis või kuhu sai ei tea.
Tänud vastajatele.
Tänud vastajatele.
Br.
