Autoks golf 5 1.9 77kw diisel automaat mis ei käivitu.
VCDS veakoodid sellised
Kood: Vali kõik
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ5B104904 Mileage: 247810km-153981miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 DF HW: 028 101 190 1
Component: R4 1,9L EDC 0000AG 6177
Revision: 12345678 Serial number: VWZ7Z0E1506653
Coding: 0000078
Shop #: WSC 80093 222 69422
VCID: 6ADC19EA45E4A91157-803E
No fault code found.
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 042 S HW: 02E 927 770 AE
Component: GSG DSG 081 1117
Revision: 04608010 Serial number: 00000705301077
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 234234CEE24EB859D4-8076
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F8A98BE6EE6FCB9D0-806A
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Q0 907 044 AJ HW: 1Q0 907 044 AJ
Component: ClimatronicPQ35 131 0405
Revision: 00131023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 75E63A961C5A76E9CA-8020
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001474241
Coding: 03898F0600041000001400001400000000087F075C
Shop #: WSC 01357 011 00200
VCID: 3A7CE9AA75C4D991E7-806E
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 01357
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 C HW: 1K0 909 605 C
Component: 07 AIRBAG VW8 013 2100
Revision: 02013000 Serial number: 0033HD054XA2
Coding: 0012343
Shop #: WSC 00046 412 16384
VCID: 2C50DFF28F90772165-8078
Subsystem 1 - Serial number: 6332MSME085B5C0EQ
Subsystem 2 - Serial number: 6342MSME0822415C6
Subsystem 3 - Serial number: 6351HSME060C043C4
Subsystem 4 - Serial number: 6361HSME061D4D2FM
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 021 0050
Coding: 0010012
Shop #: WSC 00046 412 1007616
VCID: 3566FA965CDA36E90A-8060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 861 B
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0001103
Shop #: WSC 14557 222 69422
VCID: 285823E29B685B0181-807C
1 Fault Found:
00003 - Control Module
014 - Defective
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 290010512508EA
Coding: 3F3F0B40070002
Shop #: WSC 00046 412 1679360
VCID: 295E26E6806262099E-807C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 0814
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0153
Coding: 0000052
Shop #: WSC 00046 412 1695744
VCID: 3068CB82A3B813C159-8064
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.2 1502
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 80C802087F2D8404084F01E010
VCID: 7BF22CAE3A7E2099BC-802E
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
VCID: 316ECE86A8B21AC956-8064
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 R
Component: Radio GR0 019 0023
Revision: 0001905S Serial number: VWZ2Z2F1682731
Coding: 0020200
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0213
Coding: 0000016
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Coding: 0000016
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D56D2F6B48A7E2972-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 02:09)--------------------------
