Kes ja kus oleks nõus masinat ette võtma Lõuna-Eestis?
VCDS räägib sellist asja:
Kood: Vali kõik
Tuesday,03,September,2024,14:35:50:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WVWZZZ3CZDE066621 License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4C 4F 52 53 55 56
61 62 69 6C 72 77
VIN: WVWZZZ3CZDE066621 Mileage: 336180km-208892miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CDG) Labels: None
Part No SW: 03C 906 021 Q HW: 03C 907 309 D
Component: 4414 CNG 14K31 G 6368
Revision: E8H06--- Serial number: VWZCZ000000000
Coding: 0000077
Shop #: WSC 19829 004 1048576
VCID: 290FFDB9E5FADC9220D-807C
VINID: 9E69EAAAA0D3A9454018618204CAE8FBD5
3 Faults Found
012378 - Gasoline Operation
P305A - 000 - Random/Multiple Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 336068 km
Time Indication: 0
Date: 2019.01.25
Time: 19:36:03
Freeze Frame:
RPM: 4549 /min
Load: 92.1 %
Temperature: 61.0°C
Temperature: 32.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.208 V
000771 - Cylinder 3
P0303 - 000 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 336068 km
Time Indication: 0
Date: 2019.01.25
Time: 19:36:03
Freeze Frame:
RPM: 4549 /min
Load: 92.1 %
Temperature: 61.0°C
Temperature: 32.0°C
Voltage: 13.208 V
049409 - No Communication with Transmission Control Module
U0101 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 336170 km
Time Indication: 0
Date: 2019.01.25
Time: 20:34:34
Freeze Frame:
RPM: 889 /min
Load: 20.4 %
Temperature: 63.0°C
Temperature: 30.0°C
Voltage: 13.335 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: Redir Fail!
Part No SW: 0AM 300 054 A HW: 0AM 927 769 D
Component: GSG DSG AG7 431 3645
Revision: 00043014 Serial number: CU501209295266
Coding: 0000020
Shop #: WSC 05311 000 00000
VCID: 2B0307B1EF06CE82D21-807E
No fault code found.
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 BK HW: 3AA 614 109 BK
Component: J104 C2 450M VD37 0024
Revision: --H07--- Serial number: 00000006241354
Coding: 0132465
VCID: 77ABEBC163CEBA62669-8022
3 Faults Found
02757 - Learning Tire Pressures
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 46
Reset counter: 55
Mileage: 336185 km
Time Indication: 0
Date: 2019.01.25
Time: 00:09:35
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.25 V
Bin. Bits: 00011111
Count: 194
Hex Value: 0x0000
01315 - Transmission Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 38
Reset counter: 95
Mileage: 336185 km
Time Indication: 0
Date: 2019.01.25
Time: 00:09:36
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 12.25 V
Bin. Bits: 00011111
Count: 217
Hex Value: 0x0000
03159 - TPMS Functionality in ESP
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 45
Reset counter: 55
Time Indication: 0
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 190
Hex Value: 0x0000
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 3AA 907 044 AK HW: 3AA 907 044 AK
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0014004802
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW46.rod
VCID: 79AFEDF9595AAC1210D-802C
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 H HW: 3AA 937 087 H
Component: BCM PQ47 H+ 421 0465
Revision: BC421001
Coding: 000800000000000000980280D400297423D5008A637D8F60E4C846240041
Shop #: WSC 05311 123 12345
VCID: 3FDB43E1077E42226E9-806A
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419
Component: Wischer 29081 10 0603
Coding: 00B795
Subsystem 2 - Part No: 1K0 955 559 AH
Component: RLS 021012 05 54 0403
Coding: 02302A
4 Faults Found
00061 - Footwell Lights
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 5
Fault Frequency: 1
Reset counter: 55
Mileage: 336185 km
Time Indication: 0
Date: 2019.01.25
Time: 00:10:40
Freeze Frame:
Term 15 On
Voltage: 12.20 V
ON
ON
ON
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 95
Mileage: 336185 km
Time Indication: 0
Date: 2019.01.25
Time: 00:09:35
Freeze Frame:
Term 15 On
Voltage: 12.25 V
ON
ON
ON
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 55
Mileage: 336185 km
Time Indication: 0
Date: 2019.01.25
Time: 00:10:41
Freeze Frame:
Term 15 On
Voltage: 12.25 V
ON
ON
ON
OFF
OFF
01503 - Bulb for 3rd Brake Light (M25)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 55
Mileage: 336185 km
Time Indication: 0
Date: 2019.01.25
Time: 00:21:27
Freeze Frame:
Term 15 On
Voltage: 12.20 V
ON
ON
ON
OFF
ON
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 3AE 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H06 0016
Revision: -------- Serial number: 28261226900533
Coding: 318102
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_EPHVA18VW47X0000 001005
ROD: EV_EPHVA18VW47X0000.rod
VCID: 3E253EE500F44B2A65F-806A
1 Fault Found
12648736 - Databus
U1121 00 [00001000] - Missing Message
[Getriebesteuergerät - mGetriebe_1 - kein Signal/keine Kommunikation]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 95
Mileage: 336185 km
Date: 2024.09.03
Time: 00:09:35
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__107 VW10 HI 2118
Revision: 24017000 Serial number: 003L7PKXCWS9
Coding: 0012343
VCID: 7CA1F4ED5AE8993A0BB-8028
Subsystem 1 - Serial number: 6332MTS646392472
Subsystem 2 - Serial number: 6342MTS645602482
Subsystem 3 - Serial number: 6351HTS6102TCBKJ
Subsystem 4 - Serial number: 6361HTS6JFCFDBKJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20120920200953
Coding: 1982250000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 6FBBD3A1171EF2A2BE9-803A
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H07 0022
Coding: E20000
1 Fault Found
0516 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 95
Mileage: 336185 km
Date: 2024.09.03
Time: 00:09:34
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3AA 920 870 K HW: 3AA 920 870 K
Component: KOMBI H05 0705
Coding: 161C01
Shop #: WSC 05314 115 12345
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
VCID: 3A2D32F51CDC670A597-806E
1 Fault Found
12648704 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Steuergerät für Getriebe: keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 95
Mileage: 336185 km
Date: 2024.09.03
Time: 00:09:34
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7N0 907 530 AE HW: 7N0 907 530 AE
Component: J533 Gateway H46 1633
Revision: H46 Serial number: 100912F2000076
Coding: 462006
Shop #: WSC 05314 000 00000
VCID: 73B3DFD17BB6D6425A1-8026
1 Fault Found
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 95
Mileage: 336185 km
Time Indication: 0
Date: 2019.01.25
Time: 00:09:35
Address 25: Immobilizer Labels: Redir Fail!
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 045 0400
Revision: 00045000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 76B5E6C564C4C36A7DF-8022
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0533
Revision: 12110009 Serial number: 0005742934
Coding: 0000B7
Shop #: WSC 05311 115 12345
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW46.rod
VCID: 353721C935C28872B45-8060
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795
Component: J388__TSG-HL 004 0503
Serial number: 00000003128420
Coding: 010090
1 Fault Found
66048 - Motor for Front Window Regulator
B11EC 54 [00001000] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 95
Mileage: 336185 km
Date: 2024.09.03
Time: 00:09:34
Address 44: Steering Assist Labels: None
Part No SW: 5N1 909 144 N HW: 5N1 909 148 G
Component: J500__APA-BS KL.308 1101
Revision: 1AH03735 Serial number: 00122560431601
Coding: 0000258
VCID: 3D2739E9017250327C5-8068
Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
Component: KSG PQ47 ELV 045 0634
Coding: 0091020052834E76340694157008CFCE705A01
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Subsystem 2 - Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Subsystem 3 - Part No: 3C0 951 171 C
Component: Innenraumueberw.004 0611
1 Fault Found
01134 - Alarm Horn (H12)
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 55
Mileage: 336185 km
Time Indication: 0
Date: 2019.01.25
Time: 00:10:32
Address 4F: Centr. Electr. II (J520) Labels: Redir Fail!
Part No SW: 7N0 907 532 HW: 7N0 907 530 AE
Component: EZE_2 H46 1633
Coding: 00000008
VCID: 6FBBD3A1179EF2A2BE9-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0004
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0005754422
Coding: 0010F7
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
VCID: 363526C528C4836ABDF-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794
Component: J389__TSG-HR 004 0503
Serial number: 00000003134625
Coding: 010090
1 Fault Found
66561 - Motor for mirror fold-in
B11F6 01 [00001001] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 55
Mileage: 336185 km
Date: 2024.09.03
Time: 02:37:06
Address 53: Parking Brake Labels: None
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000467638
Coding: 0022157
VCID: 363526C52444836ABDF-8062
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Reset counter: 95
Mileage: 336185 km
Time Indication: 0
Date: 2019.01.25
Time: 00:06:59
Freeze Frame:
Voltage: 12.10 V
Count: 73
Speed: 0.0 km/h
Hex Value: 0x1273
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Headlight Range (J745) Labels: None
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: --------------
Coding: 021200000B000200
Shop #: WSC 38229 001 1048576
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_VW46.rod
VCID: 372B2BC12FCE7A62A69-8062
Subsystem 1 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H04 0012
Coding: 230000
Subsystem 2 - Part No SW: 3D0 941 329 D HW: 3D0 941 329 D Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 230000
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 190 C HW: 3C8 035 190 C
Component: Radio RCD510 051 0213
Revision: 00000001 Serial number: VWZ1Z3M2037434
Coding: 05000400040011
VCID: 2313EF918BD606C26A1-8076
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AE
Component: Batt.regelung H46 1633
Coding: 33260864
VCID: 71BFD5D901AAE452A8D-8024
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 00000000008900222844
Address 69: Trailer (J345) Labels:. 7N0-907-383.clb
Part No SW: 7N0 907 383 HW: 7N0 907 383
Component: Anhaenger H09 0120
Revision: 3I001003 Serial number: 00008160040799
Coding: 4106040001000000
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C9 907 441 HW: 3C9 907 441
Component: J772__Rearview 0020
Revision: 00H11000 Serial number: 525PA8-J283444
Coding: 0030007
VCID: 6889B8BD3E70259AFF3-803C
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663456155 Dataset Number: 7P6035730J 0001
Coding: 0A01000000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 392F2DF919DA6C1250D-806C
End----------(Elapsed Time: 01:47, VBatt start/end: 14.9V/14.7V)-----------
