Hakkasin siis lihtsalt huvi p?rast uurima et mida see asi t?psemalt endast kujutab teemat foorumist leidmata:
http://www.autozine.org/technical_schoo" onclick="window.open(this.href);return false; ... kaging.htm
http://www.answers.com/topic/list-of-volkswagen-engines" onclick="window.open(this.href);return false;
[Edited on 4-1-2007 by samzik]
Natuke w8 mootorist
samzik
- Telefon: 55558855
Natuke w8 mootorist
samzik
- Telefon: 55558855
Compression ratio: 10.8:1
Engine Components Supplier Involvement
Hydraulik-Ring: Infinitely variable intake valve
Bosch: Injection, motor management
Pierburg: Intake manifold
Kolbenschmidt: Crank house
Mahle: Pistons
Emishaft: Crank shaft
Mahle: Pistons
samzik
- Telefon: 55558855
Configuration
3,998 cm? (4.0 L) WR8, two 15? "VR4" engines mated at 72?
Head
32 valves actuated by roller rocker fingers, 52? variable inlet camshafts and 22? for exhaust camshafts, 10.8:1 Compression ratio
Aspiration
aluminium resonance intake manifold
Crankcase
aluminium, five bearings, counter-rotating at twice the crankshaft speed Lancaster principle balancer shafts one above the other, symmetric to the middle of the crankshaft, upper one driven by a toothed belt
Management
Bosch Motronic
Dimensions
190 kg, 420 mm length, 710 mm width, 683 mm height
Output
202 kW (275 hp DIN) (ätt) 6,000 rpm, 370 N?m (11.6 bars MEP) (ätt) 2,750 rpm, max speed 6400 rpm (19.2 m/s)
Fuel
Regular Premium unleaded recommended for maximum performance.
Applications
VW Passat and Passat Wagon
Head
Aspiration
Crankcase
Management
Bosch Motronic
Dimensions
Output
Fuel
Applications
