B5, 2000 2,5TDI Tiptronic
tmurk
Telefon: 5164837
Auto: VW touareg, T3 :1979,1981,.....1990, Corrado, Typ 4(412)
Lugemata postitus Postitas tmurk »
Järgmine fenomen:
Passat 2000, 2,5 TDI, Tiptronic
Süüte sissekeerates( mootorit mitte käivitades)([shadow=blue] ja mitte alati [/shadow]!) läheb käigukast avariisse.
arvutiga vaadates näitab viga 18160-P1752:
Süüte väljakeerates ja uuesti käivitates kaob, samuti laseb arvutiga kustutada.
[shadow=blue]Isegi kui alustada sõitu, siis kast käituks nagu normaalselt[/shadow] ?
Milles võiks olla probleem ?
Selgitus:
Fault remedy
18160 P1752
Supply voltage for automatic gearbox control unit -J217 subject to major fluctuations/interrupted
- Use current flow diagram to check wiring and connectors
Check supply voltage to control unit -J217
Voltage supply
Voltage regulator -C1 for alternator defective
- Read measured value block
Implausible signal
- Check and, if necessary, replace voltage regulator -C1 for alternator
1) When selecting measured value block, note type of gearbox hydraulic control system. For a more detailed description, refer to Page 01-194 onwards => under "Reading measured value block".
Notes on fault code 18160 / P1752:
◆ Fault detection condition: Battery voltage less than/equal to 9 V => Gearbox switches to emergency running mode
=> Page 01-3.
◆ Failure of electrical system voltage (terminal 30) results in loss of application values, i.e. gearbox control unit has to learn these values again on restarting. Gearshift quality may be poorer than usual during this "re-learning" process.
Mine “Ülekanne”
