VCDS auto scan ka siis:
Chassis Type: 3C (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 37 42 44 46 4F 52 53 56 61
62 69 72
VIN: WVWZZZ3CZBE333312
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 BE HW: 03L 907 309 N
Component: R4 2.0l TDI X24 9978
Revision: 47X24--- Serial number: 00000000000000
Coding: 00190012043601080000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ECM20TDI01103L906018BE 003008
ROD: EV_ECM20TDI01103L906018BE.rod
VCID: 6ED32833B162DE6E76F-803B
1 Fault Found:
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 218879 km
Date: 2088.14.01
Time: 01:16:40
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 N HW: 3AA 614 109 N
Component: J104 C2 450M VD48 0005
Revision: --H07--- Serial number: 00000003610866
Coding: 0003510
Shop #: WSC 05311 256 00000
VCID: 387FCE6B4BA650DE6C3-806D
No fault code found.
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0008000003
Shop #: WSC 00015 115 12345
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_SE36.rod
Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
Part No SW: 3AA 937 087 A HW: 3AA 937 087 A
Component: BCM PQ47 H 413 0452
Revision: BB413001
Coding: 000000000000000000180080740081E443510088436D85606480C7200041
Shop #: WSC 05311 123 12345
VCID: 387FCE6B8BA650DE6C3-806D
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 11121 10 0603
Coding: 00B795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 271210 05 54 0403
Coding: 033028
Address 10: Park/Steer Assist (J446) Labels: 3AE-919-475.clb
Part No SW: 3AE 919 475 HW: 7N0 919 475
Component: PARKHILFE 8K H04 0009
Revision: -------- Serial number: 77631036408738
Coding: 118002
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_EPHVA18VW47X0000 001003
ROD: EV_EPHVA18VW4280000.rod
VCID: FCF7927B771E3CFE48B-80A9
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__101 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PRYWLSI
Coding: 0012337
Shop #: WSC 05311 000 00000
VCID: 4C9782BB2F3ECC7E38B-8019
Subsystem 1 - Serial number: 6332MTS632643400
Subsystem 2 - Serial number: 6342MTS627493400
Subsystem 3 - Serial number: 6351HTS6P230L9KJ
Subsystem 4 - Serial number: 6361HTS6QFASL9KJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C9 953 501 BF HW: 5K0 953 569 S
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101222100451
Coding: 1182250000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Coding: E20000
1 Fault Found:
229127 - Cruise Control Switch
B1154 11 [009] - Short to Ground
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 72
Mileage: 218879 km
Date: 2088.14.01
Time: 01:16:40
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3AA 920 880 A HW: 3AA 920 880 A
Component: KOMBI H02 0206
Coding: 161F01
Shop #: WSC 05314 115 12345
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 3169F34F60DC81962BD-8064
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 G HW: 1K0 907 951
Component: J533 Gateway H41 1614
Revision: H41 Serial number: 040111F2000929
Coding: 462006
Shop #: WSC 05314 123 12345
VCID: 3467FA5B97CEB4BE40B-8061
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BS 907 554 B HW: 0BS 907 554 B
Component: Haldex 4Motion 4015
Coding: 0000005
Shop #: WSC 00000 000 00000
VCID: 4581B79F0C543D36E75-8010
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0399
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: F6E38053813266AE3EF-80A3
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 HW: 3C0 035 279
Component: RNS315 H05 0010
Serial number: VWZAZ2L8367016
Coding: 000004010400000000011000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_RNS315VWEUV1UDS A01005
ROD: EV_RNS315VWEUV1UDS.rod
VCID: E0CFC60BFBB6F81E743-80B5
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0529
Revision: 12110009 Serial number: 0001987406
Coding: 0210FF
Shop #: WSC 05311 115 12345
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 3561C75F94B4ADB6775-8060
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 703 HW: 3C0 959 794 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0407
Serial number: 00000001784201
Coding: 0000D8
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.310 0802
Revision: 1AH03729 Serial number: 00103540322101
Coding: 0000258
VCID: 3B75D1677A907BC6811-806E
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ47 ELV 043 0631
Coding: 0091020052830E76300494157C084F0B607C01
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1614
Coding: 050B0508
VCID: EFEDB5373E685766FD9-80BA
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
Subsystem 3 - Part No SW: 3AA 919 204 HW: 3AA 919 204
Component: Analoguhr 003 0003
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0529
Revision: 14110009 Serial number: 0002001014
Coding: 0210FE
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 3663C05389B2A6AE7EF-8063
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 704 HW: 3C0 959 795 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0407
Serial number: 00000001798119
Coding: 0000D8
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
Component: J540 EPB4 VW-55183 0007
Revision: H18 Serial number: 00000000110426
Coding: 0022067
VCID: 3365F94752C0B386591-8066
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1614
Coding: 030B185A
VCID: F1E9B34F285C4196EBD-80A4
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Address 69: Trailer (J345) Labels: None
Part No SW: 7N0 907 383 HW: 7N0 907 383
Component: Anhaenger H07 0101
Revision: 3I001002 Serial number: 00000139841260
Coding: 4106040000000000
Shop #: WSC 05314 000 00000
VCID: F3E5B94752407386191-80A6
End ---------------------------------------------------------------------
62 69 72
1 Fault Found:
U1113 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 218879 km
Date: 2088.14.01
Time: 01:16:40
Coding: 0003510
Revision: 00003001
Coding: 0008000003
Revision: BB413001
Coding: 00B795
Coding: 033028
Coding: 118002
Coding: 0012337
Coding: 1182250000
Coding: E20000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 72
Mileage: 218879 km
Date: 2088.14.01
Time: 01:16:40
Coding: 161F01
Coding: 462006
Coding: 0000005
Coding: 0210FF
Slave Driver:
Coding: 0000D8
Coding: 0000258
Coding: 050B0508
Coding: 0210FE
Slave Passenger:
Coding: 0000D8
Coding: 0022067
Coding: 030B185A
