Passat B7 cng mootorituli ja jõuetus
Pets00
Lugemata postitus Postitas Pets00 »
Kollane mootorituli süttis ja peale seda on jubedalt uimane.
Veateated siis sellised:
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
Problem
*P3361 Misfire detection
*P3364 Cylinder 3 Misfire Detected
*P3362 Cylinder 1 Misfire Detected
*P305A Unknown fault code
*P0303 Cylinder 3 Misfire Detected
*P0236 Boost pressure sensor, incorrect signal
*P3350 Mixture adaption range 1, lower threshold
Oskab äkki keegi aidata?
Viimati muutis Pets00, 12 Nov 2020, 22:09, muudetud 1 kord kokku.
