81kw diisli pihustite kinnitusjõud?
G6S
Lugemata postitus Postitas G6S »
Kas keegi saab kiirelt vaadata, mis jõuga tõmmatakse kinni 81 kw, 99a. diisli pihustid?
Viimati muutis argo, 01 Dets 2012, 06:48, muudetud 1 kord kokku.
ValgeKotkas
Auto: Golf 3
Re: 81kw diisli pihustite kinnitusjõud?
Lugemata postitus Postitas ValgeKotkas »
http://www.myturbodiesel.com/1000q/mult ... ll-TDI.htm" onclick="window.open(this.href);return false; Lõpus numbrid pole need, mis vaja?
"Torque settings:
If you missed it, the fuel injector retaining nozzle should be torqued to wrench tight and then another 30-45 degrees. 33 ft lbs has been mentioned but this oftentimes results in leaks. If you have an accurate torque wrench, 33 ft lbs plus a 30-45 degree turn can also be used.
fuel line flare nuts: 18 ft-lbs - remember to counterhold the injector body with a 15mm wrench. CAUTION: don't overtighten the flare nuts because you could distort them and cause a leak. Tight is good, overtightened is bad.
If the other end of the fuel line (the union) in the injection pump loosened and spun, torque the union to 33 ft-lbs.
forked injector holder bolt: 15 ft-lbs - WARNING: the injector holder forks have been known to break off when torqued too much, do not over tighten!
CAUTION - the conical washer for the 13mm bolt points down. If you put it face up it will crack.
Viimati muutis ValgeKotkas, 18 Sept 2012, 12:21, muudetud 2 korda kokku.
