On kellegil sama jamaga probleeme olnud? Mis võiks aidata?
1 Fault Found:
00550 - Start of Injection Regulation
17-10 - Control Difference - Intermittent
Passat TDI 81KW AFN diagnost näitab viga?
kristo_92
- Auto: golf 1.9 55kw;toyota corolla;Mitsubishi eclipse.
Viimati muutis argo, 04 Okt 2012, 22:12, muudetud 1 kord kokku.
- J.Aru
- Tänanud: 51 korda
Re: Passat TDI 81KW AFN diagnost näitab viga?
Kontrolli kas autol süüde on paigas. Ja siis info mis selle veakoodi kohta wiki-rossis leidub:
00550 - Start of Injection Regulation: Control Difference
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Loss of Power
Starting Problems
Transmission in Emergency Mode
Possible Causes
Fuel Tank incorrectly filled with Petrol or Biodiesel
Air/Water in Fuel System
Injection Timing incorrect
Electrical Fuel Pump faulty
Possible Solutions
Check Fuel Tank for Petrol and Biodiesel
Drain Tank and Fuel System
Check Fuel System for Air/Water
Check Fuel Supply and Return Lines for Blockage and Leaks
Check Electrical Fuel Pump
Check/Correct Injection Timing
Perform Basic Setting / Use TDI-Graph
Possible Symptoms
Loss of Power
Starting Problems
Possible Causes
Possible Solutions
